Support the site. Your contributions keep this site running.
Looks pretty good. Maybe a little less height.
Paolo,Your skills are SO far above mine, its enlightening.I bow to your skills.I am watching, and hopefully LEARNING!!!Dagersh
You're moving right along, great job
Goin with a semi-stock/semi mod'ed setup on the airbox and filter like others have done. Sent from my iPhone using Tapatalk
Quote from: P.abrera on December 20, 2014, 07:43:54 PMGoin with a semi-stock/semi mod'ed setup on the airbox and filter like others have done. Sent from my iPhone using TapatalkBuild is looking great! I like that filter mod, what K&N did you go with? Do you know the name of the steel adapter you used, I'm guessing it's some sort of plumbing fitting or something similar?
Great, thanks for the info. If you want to renew the plastic airbox & other parts, a coating of peanut oil works quite well.
Pinch
Paolo,Those KZ wheels look great. Is that a caliper for a KZ, too, or did you de-fin the CB550 Tokiko caliper? Have you figured out a rear brake set up (I cannot tell if the bike was together when you bought it or in parts)?
Way to use what you have, Paolo. The front wheel and caliper matched up with no machining -- nice.
