Author Topic: New guy, first build  (Read 58116 times)
Offline P.abrera
Re: New guy, first build
« Reply #350 on: October 18, 2015, 05:39:30 AM »
Got around to converting to double disc up front. Didnt seem to need to file down the lower mount as others have had to but i did need to shim about 3 mm on the top mounts. Ran outa daylight before i got some fluid running through but fit up seems ok.
Looks so good i am doing a 550 front end swap on my cb350f with the KZ wheel.  ;D  I have a couple of questions if you don't mind.  Are you using the 550 front axle? Did you have to make or use any spacers?  Also, i am guessing you are using the KZ speedo drive?
Used the kz wheel/axle/speedo drive as is on the 550 fork, so far no problems. Make sure you use a speedo with the correct ratio though to get an accurate reading.
Offline Godffery
  • Godffery's Garage
« Reply #351 on: October 18, 2015, 05:51:15 AM »
Nice build man.
I can Pimp those Rotors for you if you'd like:
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/Parts+and+service/
Offline P.abrera
« Reply #352 on: October 18, 2015, 05:54:56 AM »
Nice build man.
Ive seen the goods
Id be all over your service if i was stateside
Keeping it in mind for the next build. Hopefully with a bit more budget to spend.
« Last Edit: October 18, 2015, 05:59:50 AM by P.abrera »
Offline Godffery
  • Godffery's Garage
« Reply #353 on: October 18, 2015, 01:00:29 PM »
 Well you did one heck of a job bring that bike back to life!
It sure looked pretty far gone!
Offline cocinero196
« Reply #354 on: December 19, 2015, 05:46:29 AM »
Sorted my oil cooler plumbing. Lines are an inch longer than i needed though my fault, mismeasured
hi paolo, was it really necessary to install an oil cooler? was there a significant difference? if so, what conversion/mods and parts does one have to get? where was your oil cooler from originally?
TIA!
Offline Zaipai
    • My Home page
« Reply #355 on: December 19, 2015, 02:40:16 PM »
Some vanity shots from last weekend
Some nice images!
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline P.abrera
« Reply #356 on: December 19, 2015, 10:11:38 PM »
TIA!
I dont know if it was "necessary" but i figured it couldnt hurt given our hot climate and traffic conditions. For a four-season country an oil cooler might work against you in the cooler months though (oil might not get up to working temp). I used a nighthawk cooler and an spin-on oil filter conversion plate from cycle-X plus some NPT braided hoses that i had made up
Offline P.abrera
« Reply #357 on: December 19, 2015, 10:12:06 PM »
Some nice images!
.: Scott :.
Thanks man
« Reply #358 on: December 19, 2015, 10:46:52 PM »
An oil cooler might come in handy in the Philippines.
Offline cocinero196
« Reply #359 on: December 20, 2015, 12:00:41 AM »
It looks OEM, nice and clean install! Very impressive! ;)
Btw, I found this...http://www.5thgearparts.com/products/1984-honda-cb550-nighthawk-oil-cooler
Is this the same as yours and would the adaptor on this work on a '77 CB550?
May I know the size of the NPT hose that you used?
TIA!
« Last Edit: December 20, 2015, 05:34:14 AM by cocinero196 »
Offline P.abrera
« Reply #360 on: December 21, 2015, 03:01:47 PM »
TIA!
Thanks
Yes, thats what i used on my build. You'll really just use the cooler radiator itself. The hoses and plate will not work with the older sohc 550's. The adaptor sandwich plate i used from cycle x will work on all the years of the sohc 550's.
Offline cocinero196
« Reply #361 on: December 21, 2015, 03:28:21 PM »
Cool! Thanks for the info! May I know the size and kind of NPT hose that you used? I'm a bit concerned about Oil pressure leakage though, especially in the fittings that'll be used, may I know how you made sure that this won't be an issue? Thanks again! Learning so much from this forum  :)
Offline P.abrera
« Reply #362 on: December 21, 2015, 04:03:32 PM »
Theres not a ton of pressure to worry about. You will need to buy the necessary fittings for the adapetr to run a cooler. You can get them at any hardware store, the size you would need is 1/4” NPT with a 1/2” barb. Braided stainless hoses are a bit overkill IMO and were more of an aesthetic choice for me. Just make sure the hose is rated for heat as it will be hot oil circulating from the crankcase coupled with heat from the headers given the location and routing of the hoses.
Offline cocinero196
« Reply #363 on: December 21, 2015, 04:55:38 PM »
TIA!
Got it! Thanks buddy 8)
Offline P.abrera
« Reply #364 on: December 21, 2015, 05:06:01 PM »
No prob. Just payin it forward. Got lotsa solid input from the good folks here when i was up to my elbows in my build
