Author Topic: 550F wiring harness resource ( #32100-390-010 )  (Read 589 times)
Offline bmoren
« on: March 12, 2014, 05:23:52 PM »
found that parts n more claims to have a 550F wiring harness for $99 for years '75-'77
http://www.partsnmore.com/parts/honda/cb550f/?filters[fitting]=custom
I am looking for my '76 550 which calls for part #32100-390-000
and parts n more says this harness is for #32100-390-010
does anyone know the difference between these 2 part numbers or should this work with my 76?
thanks!
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: 550F wiring harness resource ( #32100-390-010 )
« Reply #1 on: March 13, 2014, 02:32:13 AM »
I can't help with part numbers, however some of differences I've noted with my Aussie model F are that on mine 12v is supplied to the horn rather than it being earthed at the switch. The start solenoid is similar in that voltage is supplied rather than an earth at the start switch. Mine also has no running lights, which I think is different to the US models. The right hand control is also different to cater for these two variations. I'm not sure what you'd have to do to adapt if that's what the differences are between the part numbers you're referring to.
I don't know if that helps you at all, but good luck. I've probably done nothing but confuse you.  :o
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
