Author Topic: where to set chain first time  (Read 1092 times)
Offline skidooextreme
« on: March 12, 2014, 05:57:41 PM »
cb350f, where do i set the chain. I bought a stock chain but if i was just to connect it i would be off the swing arm before i was at the proper chain tightness. Obviously going to have to take a few links out of the 96 link but should i be at the most forward point or 3/4 back or 1/2 back.  Thanks
Re: where to set chain first time
« Reply #1 on: March 12, 2014, 06:08:54 PM »
Personal Pref: All the way forward lets you run the chain the longest without re-cutting. Further back makes the bike ride better (longer wheelbase) but you may have to cut the chain once again before it is wornout.
IMO
Offline bjbuchanan
« Reply #2 on: March 12, 2014, 10:24:38 PM »
I put it all the way forward so I don't screw with it other than adjustments for stretch over time. If riveting this can be a little fussy but master link is a breeze
Offline LesterPiglet
  • 1977 CB550F2
« Reply #3 on: March 13, 2014, 02:23:12 AM »
All the way forward.
« Reply #4 on: March 13, 2014, 05:16:38 AM »
Thanks!
Offline Powderman
« Reply #5 on: March 13, 2014, 09:15:36 AM »
IMO
So your saying keep the same chain no matter how much it stretches as long as it still fits on the sprockets?
« Reply #6 on: March 13, 2014, 10:19:18 AM »
IMO
Well, sort of. It is self limiting. At a certain amount of stretch, it won't fit the sprockets, and that's our clue to change it.
In fact, if you set the wheel/cut the chain so that the wheel is 2/3 of the way back, by the time it reaches all the way back, it probably won't fit the sprockets anymore. But assuming you're willing to trash the sprockets or were otherwise planning on replacing them, you could cut the chain and use it some more.
IF you started full forward, by the time its 2/3 of the way back it is probably time to replace it.
I just know on the CB750 you can tell the difference in ride quality when the wheel is 2/3 of the way back v all the way forward.
« Last Edit: March 13, 2014, 10:21:25 AM by MCRider »
