Author Topic: Cb550 - missing after short warm up  (Read 746 times)
Offline reddyvv
« on: March 12, 2014, 08:06:36 PM »
My bike was running super nice before I parked it up for the winter. I started it a couple of times in the late fall and it ran fine. Mid winter when it was very cold I started it up and it began to misfire after warming up for a short while. I dismissed it due to the extreme cold.
Later in the winter I put a Hondaman ignition on, cleaned and adjusted points, checked timing with strobe, etc. Still noticed the misfire problem (erratic strobe on 2+3) but again put it down to extreme cold.
A couple of days ago after finally getting some 50+ weather I started up and it ran superb with the Hondaman ignition, even as low as 500-750 before it warmed up!! As soon as it started to get warm it started to misfire again.
Checked the coils and they measured fine. What's the opinion? I'm thinking that there's a short on the coil when it warms up and those thermal issues are hard to detect.
What's a good replacement coil?
Thanks for any input!!!
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: Cb550 - missing after short warm up
« Reply #1 on: March 13, 2014, 01:19:33 AM »
Before condemning the coils there's a few things to check.
1. Measure the resistance of the plug caps. 5kΩ
2. Before you put the caps back onto the leads, snip about a quarter of an inch off the end of each lead.
3. Swap the plugs from 2 & 3 to 1 & 4 (just to see of the miss moves if it's still there)
4. Make sure to measure the voltage at the coil + when running. Should be the same as battery voltage. It might need some bullet connections cleaned up if voltage is low.
5. Run it in the dark with the tank off. Look for a lightning show from the leads to the head cover.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #2 on: March 13, 2014, 10:44:26 AM »
Sounds fuel related to me. Do you close the choke to start it and then open it and it starts missing? Have you checked each the pipes for heat? The pilot jets get clogged super easy with such a tiny jet size. If need be you can remove the bowls without taking the carbs off the bike and remove the pilot jets to give them a good cleaning. I usually have to do this every spring, its part of my de-winterizing process.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline reddyvv
« Reply #3 on: March 18, 2014, 01:32:11 PM »
Thanks for the suggestions folks.
Ding, ding, ding!! #3 wasn't making good contact at the cap. Funnily enough, it would only start missing after 3-4 minutes of running.
Offline Frostyboy
  • Circa 1951
« Reply #4 on: March 19, 2014, 01:29:32 AM »
Beautiful. Thanks for reporting back.  ;)
We haven't met yet.
[CB550F1]
