SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
Project Shop
Topic:
'75 750 Carburetor Link Arm (Shaft?) sticking
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: '75 750 Carburetor Link Arm (Shaft?) sticking (Read 1175 times)
hedog
Full Member
on:
March 15, 2014, 02:11:45 PM »
I've had my 750 for a couple of years now and the throttle has ALWAYS been slow to close. So this winter I took the carbs off and cleaned them up and also wanted to address the sluggish throttle response. This is my first bike and I'm not sure what I should be trying to fix on this. I know that I could try to replace the throttle return spring, but even without the spring it takes a fair amount of pressure to get the carbs to open and close. I attached links to some videos. One has the spring attached and the other is without the spring. Thanks.
With the spring attached
CB750 with throttle return spring
Without the spring attached
CB750 without throttle return spring
Logged
seanbarney41
not really that much younger than an
Really Old Timer ...
Re: '75 750 Carburetor Link Arm (Shaft?) sticking
Reply #1 on:
March 15, 2014, 06:39:19 PM »
I recently had this problem with a set of pd42a's...turned out number 4 throttle body got mis-shapen during shipping causing the slide to stick. Had to replace the number 4 carb body. You are probably gonna have to take those carbs off the rack so you can isolate the problem.
Logged
Johnie
Reply #2 on:
March 15, 2014, 08:54:30 PM »
Loosen all 4 of the slide hold down large caps by unscrewing them a little. See if they go any easier. I had some that were not centered. I had another set that the slide bar was real dirty, but you could not see it under the sleeve.
Logged
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI USA
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Project Shop
Topic:
