Author Topic: Oversize swingarm for cb750 easy to mod.  (Read 1371 times)
« on: March 15, 2014, 09:16:52 PM »
I am posting it here because. It is easy to modify,and being steel,very easy to weld.
 Suzuki, ...will find out year model. ..Soon.
 The eccentric is a product I used to supply to a big frame maker,still have some parts left.
Swingarm is about 6 over but as I mentioned, easy to change.
« Last Edit: March 15, 2014, 09:19:14 PM by 754 »
Re: Oversize swingarm for cb750 easy to mod.
« Reply #1 on: March 15, 2014, 09:23:57 PM »
Will take huge tire if you mod your frame.
« Last Edit: March 15, 2014, 09:26:41 PM by 754 »
« Reply #2 on: March 15, 2014, 10:04:57 PM »
OK Frank, you've peaked my interest, I do have a pair of late model 17 inch wheels that I'm thinking of puttting on a 750, so I'm subscribed. Cheers, Terry. ;D
« Reply #3 on: March 15, 2014, 10:23:33 PM »
 I think it's off a 82-84 or 92-94 Suzi 1150.
 The tire in the pic is over 6 1/2 inches of tread.... Or shall I say contact patch..Bet that would bite.
Offline BPellerine
« Reply #4 on: March 16, 2014, 11:15:30 AM »
swingarm does not look out of place like some do as well.bill
1978 CB 750K ard and webers
another anfob
« Reply #5 on: March 19, 2014, 09:10:20 PM »
89 Katana 750 is what the swingarm is from.
Offline squirley
« Reply #6 on: March 19, 2014, 10:16:41 PM »
Frank, I gotta ask...do you make those eccentric adjusters to sell? I have been looking all over for a weld in set for a custom swingarm! If you do, I'd love to get a set or two off you!
« Reply #7 on: March 20, 2014, 08:15:22 AM »
I did make them, still have the center parts I think will check. Do you want steel or aluminum outer. If both pieces are aluminum, one should be anodized. . The axle holes are 3/4 but I can open them to 19mm.
Offline squirley
« Reply #8 on: March 20, 2014, 08:36:50 AM »
Frank,
The outer would be steel with aluminum inner! I am actually looking for a 17mm axle diameter.  Let me know if you can make a set or two!
Thanks
Jens
« Last Edit: March 20, 2014, 08:46:06 AM by squirley »
« Reply #9 on: March 21, 2014, 03:04:52 PM »
I got several. Inner sets, 3/4 bore..19mm.
 But only one steel outer, it's 3 7/16    by 1 inch.... The inner and outer weigh about 2 lbs kinda heavy.
