Author Topic: Acorn nuts...  (Read 1233 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
Acorn nuts...
« on: September 11, 2006, 12:27:38 PM »
Help!  Does anyone know the pitch of the acorn nuts that mate with the upper
shock bolt..the one implanted in the frame on the 750. I tried every acorn nut that
Ace had and the closest was a #10 ...  .125 pitch.  Honda must have invented a
special for this one!
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline DME
Re: Acorn nuts...
« Reply #1 on: September 11, 2006, 12:34:07 PM »
You can buy new chrome nuts from Honda.  Not expensive, paid equivalent of 4$ for two....
/Daniel
eldar
Re: Acorn nuts...
« Reply #2 on: September 11, 2006, 03:48:45 PM »
acorns are a pain, so few hardware stores carry a good selection of them. They do standard but hardly any metric, which is funny since most vehicles these days are metric now. I have a pain finding ANY metric nut or bolt where I live. Or washers that are not to big on the O.D. yet large enough on the I.D.
Makes you want to scream sometimes. :P
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: Acorn nuts...
« Reply #3 on: September 11, 2006, 05:25:57 PM »
We must be lucky here in Toronto (and Michigan/Illinois).  www.brafasco.com - I buy all my fasteners from them, including metric acorns.
I seem to recall ordering new shock acorns for the 550 from them, but maybe from Honda.  Not sure.  Honda for sure has them though.  Replace the washers under them with nice heavy duty stainless ones.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Offline aptech77
Re: Acorn nuts...
« Reply #4 on: September 11, 2006, 06:48:46 PM »
I had a sim prob on my shocks. I think they are 10x1.00 Just buy from Honda. You will have a hard time finding them. They are odd ball.
Offline oldbiker
  • I HATE RAIN
Re: Acorn nuts...
« Reply #5 on: September 12, 2006, 12:31:47 AM »
They are actually 10mm dia by 1.25mm pitch. If you can't find them anywhere else try
 www.custom-fasteners.co.uk/
Re: Acorn nuts...
« Reply #6 on: September 12, 2006, 04:38:33 AM »
A PAO (Previous #$%* Owner) of my K3 shortened the threaded portions of the top shock mounting stud, so I had to cut them off flush, then drill and tap the cast "boss". (this was a bastard of a job because the "boss" is a super hard item, and I destroyed a couple of drill bits in the process.
At the time I couldn't get any 10 x 1.25 mm stainless threaded rod, or a stainless bolt with a long enough threaded portion, so I tapped it for 10 x 1.5mm and use two stainless bolts with the appropriate spring and flat washers. It's hardly noticeable, and makes shock removal and refitting a snap! Cheers, Terry. ;D
Hop on a Honda
Re: Acorn nuts...
« Reply #7 on: September 12, 2006, 05:13:26 AM »
I have a pair of retaing nuts on my K5 750 that have a recess machined into the outer portion them so as the bungee strap I use to tie down my ON bag etc will not slip off.
I agree its a strange TP/MM
Dave Australia
