SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
2014 Relay Rally... IT'S OFFICIAL!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 2014 Relay Rally... IT'S OFFICIAL! (Read 339 times)
madmtnmotors
When did I get to be a
Really Old Timer ...
Sunny Central Florida
on:
March 19, 2014, 09:11:21 AM »
We now have a separate planning/organizational heading for the 2014 relay:
http://forums.sohc4.net/index.php?board=171.0
WooHoo!
Logged
TAMTF...
Wilbur
Projects:
"Evolution":
http://forums.sohc4.net/index.php?topic=100352.0
"P.O. Debacle":
http://forums.sohc4.net/index.php/topic,126692.msg1441661.html#msg1441661
F2/F3 O-rings:
http://forums.sohc4.net/index.php?topic=113672.msg1300721#msg1300721
Cam Tower Studs:
https://www.mcmaster.com/#93210a017/=t19sgp
Clean up that nasty harness:
http://forums.sohc4.net/index.php?topic=137351.msg1549191#msg1549191
Charging system diagnosis:
http://forums.sohc4.net/index.php?topic=1012.msg8345#msg8345
Get the manuals:
http://manuals.sohc4.net/cb750k/
The Dragon:
http://forums.sohc4.net/index.php?topic=45183.msg1571675#msg1571675
Headlight Switch:
http://forums.sohc4.net/index.php?topic=113986.msg1283236#msg1283236
Branden's leak free top end thread:
http://forums.sohc4.net/index.php?topic=107040.0
Engine Lifting Made Easy:
http://forums.sohc4.net/index.php/topic,58210.msg1684742.html#msg1684742
Static and Dynamic Timing:
http://www.hondachopper.com/garage/carb_info/timing/timing1.html
Airbox Gasket Replacement:
http://forums.sohc4.net/index.php/topic,114485.msg1290000.html#msg1290000
"Café" :
http://forums.sohc4.net/index.php/topic,84697.msg953814.html#msg953814
PD Carb Choke Linkage:
http://forums.sohc4.net/index.php/topic,100352.msg1669248.html#msg1669248
Follow up on your damn posts:
http://forums.sohc4.net/index.php/topic,144305.msg1791605.html#msg1791605
Taiwanese Cam Chain Tensioners:
http://forums.sohc4.net/index.php/topic,155043.msg1774841.html#msg1774841
Gumtwo Seat Cover:
http://forums.sohc4.net/index.php/topic,164440.msg1897366.html#msg1897366
Primary Drive:
http://forums.sohc4.net/index.php/topic,166063.msg1919278.html#msg1919278
Tank Latch:
http://forums.sohc4.net/index.php/topic,165975.msg1919495.html#msg1919495
Shorten your forks:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-shorten-forks-td4042465.html
DO NOT CUT THE SPRINGS!
Clutch How To:
http://vintage-and-classic-honda-s.456789.n3.nabble.com/How-to-change-and-adjust-a-clutch-SOHC-td4040391.html
Late model K7/K8/F2/F3 front sprocket cover removal:
http://forums.sohc4.net/index.php/topic,178428.msg2072279.html#msg2072279
630 to 530 conversion:
http://forums.sohc4.net/index.php/topic,180710.msg2094423.html#msg2094423
Sent from my Tandy TRS-80!
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
