Author Topic: Cycle X (Mac) Drag Pipes (short ones)  (Read 10597 times)
Offline Stoli
« on: March 20, 2014, 10:44:44 AM »
Anyone have or had a set of these:
http://www.ebay.com/itm/Cycle-X-BLACK-Drag-Pipes-Honda-CB750-Chopper-Bobber-Cafe-Hot-Rod-/200844013122
They look very similar to the Mac drag pipes. Anyone know if they are the same?
If anyone has a set, I am interested in a few things, like:
- Do the the rear bracket(s) hang from the main foot peg(s)?
- What is the Inner and/or Outer diameter of the pipes?
- Do the pipes hang in the same horizontal plane or is one higher than the other?
- Ground clearance - In relation to the foot peg bolt (exhaust bracket mounting hole):
            how much lower is the center of the inner pipe?
            how much lower is the center of the outer pipe?
« Last Edit: March 20, 2014, 02:26:32 PM by Stoli »
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline Stoli
Re: Cycle X Drap Pipes (short ones)
« Reply #1 on: March 20, 2014, 11:15:26 AM »
OK - So I got confirmation that they are in fact Mac pipes.
So if anyone has a set of the Mac Slash Cut TT Drag pipes (69-76), can you help me out with my questions?
Thanks.
My Project Threads:
Offline Powderman
Re: Cycle X (Mac) Drap Pipes (short ones)
« Reply #2 on: March 20, 2014, 12:45:48 PM »
Can't answer those questions. Are you not interested in how they perform? I see only negatives for those pipes unless used in a high RPM application.
Offline Lostboy Steve
« Reply #3 on: March 20, 2014, 01:07:29 PM »
I think those are going to be uncomfortably loud, also without heavy engine mods will probably reduce performance.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #4 on: March 20, 2014, 01:13:26 PM »
I have a couple sets of those hangin' around the shop...definately not a performance improvement in any rpm range and sound like noisy crap imo.  I could get the tube measurements for you but I am not gonna mount 'em up on anything any time soon.  Yes 1 and 4 are mounted kind of diagonally higher and more outside than 2 and 3.  Ground clearance sucks.  They mount off the main footpeg.
Offline leaderbean
  • '76 550K
    • Bike EXIF
« Reply #5 on: March 20, 2014, 01:13:54 PM »
I was really disappointed that when Cycle X finally introduced pipes for the 550 - it was just the MAC ones.  I'm still hoping for pipes similar to their 750 stuff
Is it summer yet?
Offline Stoli
« Reply #6 on: March 20, 2014, 01:14:24 PM »
I'm no expert but I have familiarized myself with the intricacies of resonance, scavenging, back pressure, etc. and their effects on power production and loss in different throttle ranges. I have read all the opinions regarding the quality of the Mac exhaust systems. I'm just interested in some low cost headers for a bike that I have lowered a bit and, as such, has some ground clearance issues with certain header configurations. Just having some fun with it and am not looking to win any races. I will probably modify them with some inserts or possibly extend them a bit with some type of baffle. One step at a time.
For now, I just want to find the answers to the above questions. There also seems to be a few guys who have had difficulty with side stand clearance using the Mac drag pipes. I'd like to hear more from someone who experienced that as well. Some of the pictures I have found (that appear to be bikes with the Mac pipes) are perched on side stands so it would seem that is something that can be overcome fairly easily if it is a problem at all.
My Project Threads:
Offline Stoli
« Reply #7 on: March 20, 2014, 01:32:43 PM »
Your comment regarding ground clearance is surprising to me.  The pictures I have seen look like they are higher off the ground than any aftermarket 4-1 and even higher than the stock 4-4 for that matter!
I think all of my questions can be answered with the pipes off of a bike if you are willing to spend a few minutes with a ruler. It looks like each side has a clamp arrangement where 1 and 4 are attached to the footpeg and 2 and 3 are attached to 1 and 4 respectively. With the pipes bolted together, if you could measure (doesn't have to be exact) the horizontal and vertical distance from the center of the hole (that the footpeg bolt goes through) to the center of each pipe, that would be awesome.
If you don't know what I mean, please let me know and I'll post a picture.
My Project Threads:
Offline Ewan 500K1
    • Adams Bros Probe 2001
« Reply #8 on: March 20, 2014, 01:43:09 PM »
no probs with ground clearance here , yeah they make a racket but can be baffled. Outside diameter on mine (which look idential to cyle X , but dunno where they atually came from) is one and a half inch. Has standard side stand (which hits off the bottom exhaust in the raised position .. but no big deal)
« Last Edit: March 20, 2014, 01:58:04 PM by Ewan 500K1 »
jings, crivens, help ma boab
500 four K1 cafe racer build thread at :
http://forums.sohc4.net/index.php?topic=100883.0
« Reply #9 on: March 20, 2014, 01:51:20 PM »
I will try and get those measurements for you in the next couple days.  Yes, ground clearance is really bad with them, even though it doesn't look like it.  The only reason I have them is because they came on a couple running parts bikes I have purchased over the years.  I would ground them just making low speed turns on to side streets and stuff like that.  Sidestand will work but interferes with pipes.  You are going to burn rubber on your boots everytime you kick the side stand.  I found some pics of them mounted here...
http://forums.sohc4.net/index.php?topic=80592.175    ...about halfway down the page.
Offline Stoli
« Reply #10 on: March 20, 2014, 01:52:17 PM »
no probs with ground clearance here , yeah they make a racket but can be baffled. Outside diameter on mine (which look idential to cyle X , but dunno where they atually come from is one and a half inch.
Thanks! I forgot to mention that the bike is a CB750. The pics from your build are a big help to see where the pipes sit in relation to one another. I just read that the glas-pak inserts that Mac sells for their 69-76 CB750 drags are 1-5/8" so they are a little larger in diameter than the pipes on your 500 but the bend geometry looks to be the same.
My Project Threads:
Offline Stoli
« Reply #11 on: March 20, 2014, 02:08:35 PM »
The 2 and 3 pipes on that bike look to be sitting a lot lower than other pictures I have seen. That would account for the ground clearance problem. Are the brackets bent?
I guess this is going to be harder than I thought because there seems to be a lot of variation in the geometry of these things. For instance, here is a pic of the chromed Mac drags from the cycle x site:
To look at it, you'd think the 2 and 3 pipes sit higher than the 1 and 4 ??? :o :-\
« Last Edit: March 20, 2014, 02:35:37 PM by Stoli »
My Project Threads:
Offline Stoli
Re: Cycle X (Mac) Drag Pipes (short ones)
« Reply #12 on: March 20, 2014, 03:04:24 PM »
I don't know if my bracket depiction or pipe relationship in this drawing is accurate, but here are the measurements I was hoping to find from a:
CB750K 69-76 4-4 Drag TT Pipes Slash Cut Exhaust System
My Project Threads:
« Reply #13 on: March 20, 2014, 04:05:13 PM »
Look at the pipes on the 500, Ewans bike, they sit the same, it looks like they are only sitting straight side by side in the unmounted pic because they are sitting on a flat surface, the pipes on Ewans bike would scrape easily, especially under a competent rider.... ;)
Offline Stoli
« Reply #14 on: March 20, 2014, 04:18:21 PM »
Point taken. Look at the vertical bracket though. If one were to imagine that as perfectly vertical when mounted on a bike, it looks like the outside pipes would actually be higher. I'm sure they are not though. I was just trying to point out one of the reasons for my confusion here. Also, the pic of the chrome pipes is from a 77-78 set. I didn't think that would make a difference at the peg mount but maybe I am wrong.
My Project Threads:
Offline jamesb
« Reply #15 on: March 20, 2014, 08:46:52 PM »
Here's the diameter of my pipes outside is 41.3mm inside is 41.2mm. Mine are mounted like your picture. And here is two pictures of mine.  Hope this helps.
Offline Ewan 500K1
« Reply #16 on: March 20, 2014, 11:51:54 PM »
hands up to being fully incompetent rocket, but never bottomed them out in 17 years .. how low can ya go ...;) . Here's another picture of the 500 / 550 mac ones from CycleX .. all fittings etc look identical to mine. Also a picture of the baffles.
« Last Edit: March 21, 2014, 12:00:02 AM by Ewan 500K1 »
Offline Stoli
« Reply #17 on: March 21, 2014, 07:39:01 AM »
Thanks Ewan. I enjoyed reading through your build thread. Really nice job with the bike and the documentation. Do you have those baffles installed in your pipes? Didn't see any mention of them in your thread.
I would think that the rider who scrapes his pipes is the incompetent one. Don't you think?   ;)
My Project Threads:
Offline Stoli
« Reply #18 on: March 21, 2014, 08:19:41 AM »
Thanks for taking the time to measure and post the pics james. You must have made one of the measurements on a slightly oval spot though. Either that or your pipes are paper thin (.05mm). I would think there would be an 1/8" (3.1mm) difference between the ID and OD. I'm not positive but I think they are 1 5/8" inner and 1 3/4" outer  ??? which would make your inside measurement (41.2mm) accurate.
My Project Threads:
Offline thelowmax
« Reply #19 on: October 22, 2014, 01:42:21 PM »
I realize I'm posting months later but I was curious how those drag pipes worked out for you. Did you end up using them? Have you tried the baffles?
« Last Edit: October 26, 2014, 03:28:25 PM by thelowmax »
What am I doing and why am I doing it? Those are excellent questions.
'72 Amen Savior/'77 CB750K Chrome/Da Bhudda(project)
'73 CB750K Green/El Verde (beat)
'76 CB750K Red/The Cinnabomb (sweet)
'77 CB750K Black (frame and parts) CANNIBALIZED
'77 CB750K Dark Purpley/Scooty Puff, Jr. (la beast)
'78 CB750K Black (struggling) SOLD
'78 CB750K Blue Flake/CiocioSan (minty)
'81 CB750C Poiple/Barbie'sDreamMotorcycle SOLD (darnit!)
'89 Trek 21" 21 speed Green/YaBiatch (the wife)
Converse One Stars size 8.5 Black/Sneaks (suede)
Offline Stoli
« Reply #20 on: October 22, 2014, 02:45:12 PM »
I wound up making my own out of some old K8 headers and some stainless steel tubing:
They are probably very similar in performance to the Macs. I never tried them without baffles. I fitted them up with short baffles like the one pictured in Ewan's post earlier in the thread. They are about what you would expect. A bit loud even with the baffles but it's a nice throaty sound none the less. Tuning wasn't too bad. I don't notice any power loss in the mid range but I haven't put it on a dyno or anything. There is a bit of popping during decel/downshifting which I attribute to the pipes. Popping can also be caused by a lean mixture but my plugs are a nice tan color so I think the mixture is good. The bike idles really well and throttle response is great throughout the range with the exception of a very slight hesitation (sometimes) just off idle when the bike is at speed. It isn't there when accelerating from a stop so I attribute that to the lack of an air box (takes a moment for the carbs to overcome the turbulent air). It is very slight and doesn't bother me but worth mentioning. I have plenty of ground clearance and could drop the bike even lower with no problem. My frame mods lowered the bike 2.5" but the Firestone tires raised it back up an 1" or so compared to Avon Roadriders or something comparable.
My thoughts - I like them on this bike. They have the look I was going for and are "good enough" performance wise. I'd like them more if they were a little quieter. I wouldn't recommend them unless you were putting form ahead of function. I don't think you can beat a good 4-1 system for all around performance.
My Project Threads:
Offline thelowmax
« Reply #21 on: October 26, 2014, 03:30:22 PM »
Did you have to rejet with the baffled drag pipes? (or was that due to the velocity stacks?)
Offline Stoli
« Reply #22 on: October 26, 2014, 05:43:05 PM »
Both. The velocity stacks more so than the pipes, but I can tell from the sound that the drag pipes with the baffles I used are less restrictive than the stock exhaust. I noticed your other post today inquiring about the need to rejet with baffled drags and I would say that it depends on the baffles as some would be more restrictive than others. In the case of the baffles that I used, and probably in most cases, there would be a need for slightly larger main jets and possibly a needle adjustment.  Free flow intake or air cleaners tend to affect everything from idle to wide open throttle where open headers or exhaust with only mild baffling affect the throttle from about 1/3 to wide open throttle. That would mean that if you just changed the exhaust, you shouldn't have to change your slow jets but might consider going up a size or two on the mains. The year/model would also affect things since the later SOHC (77 & 78) were tuned lean from the factory to begin with, so those bikes might benefit from an even bigger jump in size.
My Project Threads:
Offline thelowmax
« Reply #23 on: October 27, 2014, 10:05:24 AM »
I see they also make several size baffles. I just sent a note to MAC, asking what the comparative compression rates are for the drag pipes, with the various baffles. I'll post any info they give me.
« Reply #24 on: October 27, 2014, 03:16:52 PM »
Mac isn't a performance pipe builder, I seriously doubt they would have any info like that at all...
