Author Topic: '78 CB550 Seat Help Needed  (Read 5720 times)
Offline macisaguy
  • Yeah, I'm New
« on: March 21, 2014, 07:11:40 AM »
So now that winter's over, taxes have been paid, and brakes have been fixed on the truck, it's time to start putting some more cash towards the bike.  I'm looking to upgrade the goofy after-market seat that came with my '78 CB550.  Here's what it looks like now (the before and after is referring to the shorter front forks I put on):
Looking for a low/flat Brat style seat that will still fit two riders.  Something like this:
This is my first bike, and I'm learning as I go.  I'm not even sure what I need to know for a seat replacement.  I have no idea if my bike frame will support a brat seat like this, or what measurements are needed.  The seat I have now is on a hinge, and I don't know if I can swap it out, or if I'll have to change the frame in some way.
Can someone help me get started on what I need to look for/what I need to know/what I need to avoid?  I really am flying solo on working on this bike, and am learning as I go.
Turns out bikes don't come with babes.  Apparently I was misinformed.
Offline Bankerdanny
  • Endeavor to persevere
Re: '78 CB550 Seat Help Needed
« Reply #1 on: March 21, 2014, 10:07:55 AM »
Seats like that aren't difficult to fabricate. It's basically just a piece of steel or aluminum with a pad on it. If you want to retain the hinge and lock mechanism that is a somewhat more complicated bit of work, but still doable.
I would do an eBay search in the MC seat section for 'brat honda CB550. I suspect you will find several options.
I also think that several of the usual suspects for semi-custom parts (Dime City Cycles for example) sell this kind of seat.
« Reply #2 on: March 22, 2014, 12:51:09 AM »
your doing the right thing,man what is that seat?who thought what when that got made?
Offline 750K
« Reply #3 on: March 22, 2014, 02:32:41 AM »
Wtf is with the rear end on that bike you used for an example, haha. The tire looks like its touching the seat pan without a rider on it...
77 Cb750, 78 Kz1000
« Reply #4 on: March 22, 2014, 02:50:06 AM »
thats an example of what not to do!im guessing those firestones have plenty of "armourall"on the tread for the gloss?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #5 on: March 22, 2014, 04:00:31 AM »
To put a flat seat like that on you are going to need to remove the frame hump and rear fender.
Offline b5rider
« Reply #6 on: March 22, 2014, 09:51:20 AM »
you would be surprised how flat you can make the seat by just cutting the foam down and reupholstering it. I did it to my wife's CB400 and the seat is perfectly flat without any modifications to the seat pan. It might take some creative shaving of the foam, but you can get a flat profile with just foam trimming.
BTW, it won't be iron-butt-day-long-ride soft, but it's very tolerable around town.
« Last Edit: March 22, 2014, 09:58:20 AM by b5rider »
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
Offline b5rider
« Reply #7 on: March 22, 2014, 09:57:19 AM »
I figured this would be the next question, so here is a picture of the bike. Like I said, no modifications to the stock seat pan
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
Offline 750K
« Reply #8 on: March 22, 2014, 10:45:16 AM »
Good looking seat on the 400, I did something similar to a spare stock seat pan on my 750. I need to redo it with a bit more foam so I've got the stock seat back on it, my ass started to get sore by the end of any all day rides last season. Around town was fine, I'm going to play around with the profile of it a bit. It's pretty thin at the back end as I wanted it fairly flat but I don't do any two up riding.
77 Cb750, 78 Kz1000
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #9 on: March 22, 2014, 04:11:39 PM »
+++1 on the sore ass!  My K1 has a cut down stock seat pan and I am glad I only ride it around town.  That's bad enough!  Don't chop the stock frame.  Cut a spare seat pan down like 750K.  A future owner or you can return it to stock if you decide you don't like the brat look.  However if you must; Motovocation and Dime City Cycles and many others have the cafe hoop's and finished seats either flat or up swept.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline macisaguy
  • Yeah, I'm New
« Reply #10 on: March 23, 2014, 07:57:38 PM »
Thanks everyone for the responses!
Offline macisaguy
  • Yeah, I'm New
« Reply #11 on: March 25, 2014, 01:34:38 PM »
Still thinking about shaving down, and reupholstering the seat....but may not be able to shave down much, as the seat pan is the real problem...as it's molded incredibly high in the back.
Have a lead on a reasonably priced '73 CB500 seat.  Any idea if that would fit on my '78 CB550?  Parts Fische has two different part numbers for the CB500 and the CB550 seats...but does it make a huge difference?
Any input is a huge, huge help.  Thank you.
Offline 750K
« Reply #12 on: March 25, 2014, 10:12:41 PM »
Rip your seat down to the bare pan, strip the vinyl and foam off. Get some good high density foam and hot glue it down build it up to the profile you want, shaping it with an exacto knife or orbital sander. Then add a final layer of softer density foam and recover it or take it to a good upholstery shop and have them recover it. There you have your brat style seat, pretty simple. Especially if you already hate the seat that's on it, you have nothing to loose.
77 Cb750, 78 Kz1000
Offline brewsky
« Reply #13 on: March 26, 2014, 04:10:09 AM »
+1 on the upholstery shop.
I would just take the seat along with a pic of what you want it to look like, and get it done right.
Should be less than $100 even with new foam.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline 750K
« Reply #14 on: March 26, 2014, 10:25:54 AM »
I built mine from a bare pan from scratch, the only mistake I made was not adding enough foam. I still got 2 years out of it before it was to packed out for all day rides, my total cost was under $100 and that's including buying a second seat pan.
77 Cb750, 78 Kz1000
Offline macisaguy
  • Yeah, I'm New
« Reply #15 on: March 26, 2014, 12:58:07 PM »
Okay...looking into solid upholstery shops in town.  Thanks for the straight forward advice.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #16 on: March 26, 2014, 04:25:17 PM »
I went the upholstery shop route I was happy I did. I bought the seat pan and a seat cover in the they did the rest. It looks great still does.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
