Author Topic: '77 CB550F Kickstarter Gear/Spindle Assembly  (Read 1410 times)
Offline dagersh
    • Photos
« on: March 23, 2014, 12:15:00 PM »
HI Guys,
I am putting the engine back together, and I may have hit a snag...  serves me right for not photo-documenting this assembly.
I don't see any other way for this to go back together, and with all the springs that hold it together, I can't really test it until the engine is back together.  It wouuld SUCK to figure out I did it wrong at that stage, so if anyone can see anything wrong here, I am all ears.
Thanks as always!
The Outside:
The Inside:
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Re: '77 CB550F Kickstarter Gear/Spindle Assembly
« Reply #1 on: March 23, 2014, 12:43:21 PM »
you nearly got it,looks like this.
that lump on the shaft rests against the bump on the case under spring tension.
Offline dagersh
    • Photos
« Reply #2 on: March 23, 2014, 01:24:08 PM »
Thanks Dave!
That makes much more sense and no slop!!!!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
« Reply #3 on: March 24, 2014, 12:06:23 AM »
no worries,make sure that small circlip on the inside is new or in good condition and the correct way around,they are stamped out and have a flatter sharper edge one side,that should face toward the end of the shaft inside,also a washer goes over the kickshaft against the other circlip and the case holds it in,its often missing.
Offline dagersh
    • Photos
« Reply #4 on: March 24, 2014, 12:23:03 PM »
Dave,
Great tips.  I think I will replace that 12mm Circlip on the inside, its pretty weak and I had to bend it back tighter.  I have not put the cases together yet, so I will take care of it this weekend.
I have the 18mm Washer for the Pedal Side.
Again, thank you for the guidance!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
