Author Topic: Sprocket carrier seal/bearing retainer different threads?  (Read 833 times)
Offline Garage_guy_chris
« on: March 24, 2014, 09:11:35 PM »
Tonight i got around to working on the rear wheel i was gonna do the bearings and seals, I started working on my polished carrier to destroy the threads and wrecking the part. I grabbed a second one. I took it appart to find about 1/3 of the threads chewed and the outside all chewed up and ruined. So i grabbed what i thought was a later DOHC hub to try my luck and found it had a SOHC sprocket carrier?!?!? upon disassemble i found more damaged threads but not enough to trash the part.. but upon looking closer this last bearing retainer has a much coarser thread. I figured it was just a early vs late part or something.
I checked CMSNL and found all the seal/bearing retainers are the same P/N 41231-283-000 and all have a fine thread. At this point i have no idea what it is the only thing i can think of is its early sandcast or something?
anyone have any ideas about this coarse vs fine threaded retainers?
I have the one coarse thread then the two fine thread retainers?
Here are the carriers outside of condition they all appear the same?!?!
Offline shinyribs
Re: Sprocket carrier seal/bearing retainer different threads?
« Reply #1 on: March 24, 2014, 09:26:57 PM »
Do they all the cush drives have the same amount of offset?
69-76 cushdrives are one thing. But the 77-78 models had the primary sprocket moved outboard 10mm and the cush drive was spaced to match. Maybe that is the difference?
« Last Edit: March 24, 2014, 09:28:48 PM by shinyribs »
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
« Reply #2 on: March 24, 2014, 10:37:21 PM »
They are all the same with the same offsets, which leads me to believe they are 69-76, the 77-78 don't have the 8 ribs from the stud bosses. the coarse one looks different because someone has painted it along its life
« Last Edit: March 25, 2014, 12:06:12 AM by Garage_guy_chris »
« Reply #3 on: March 25, 2014, 08:43:22 AM »
Do the retainers look factory?
 Common machine shop practice is the machine a bigger OD thread and make a retainer,  if stuck or in a hurry.
« Reply #4 on: March 25, 2014, 11:18:40 AM »
I think i have this figured out...  I believe its a CB650 cush drive plate
Here is the 750 retainer P/N 41231-283-000
Here is the 650 retainer P/N 41231-422-000
