Author Topic: 72 cb500f engine rebuild  (Read 2249 times)
Offline Chrispy56
« on: March 25, 2014, 05:02:23 AM »
I recently picked up a 72 cb500/f for a good deal. The previous owner started a café project out of it and gave up. I will continue this project as a café but plan to keep it very simple and mostly oem components. While discussing details of this bike the previous owner had stated that he had torn the motor down "just because"...? reassembled, painted it and put it back in the frame. I have noticed gaskets missing causing oil to leak and an assortment of parts in a box that didn't make it back in the motor.  Everything else on the bike is there. brakes need rebuilding and needs a seat. other than that it is in good mechanical shape.
     So, with that said I would like to first tear down the motor for inspection. I understand that the 500 didn't have the greatest transmission setup, but am not sure of the specifics. what should I be looking for? where are the failure points? are there heavy-duty replacement parts available? any recommended parts suppliers?
Thanks for any input,
-Chris
Offline calj737
  • I refuse...
Re: 72 cb500f engine rebuild
« Reply #1 on: March 25, 2014, 05:13:15 AM »
A complete Vesrah brand gasket set may be a good idea. Depending upon how far you take the motor down, (did the PO indicate that?) you may want to re-ring and hone it.
There's a member on here, Dave500 who is extremely knowledgeable about the 500 and it's particular idiosyncrasies, plus many others with great knowledge and expertise on these bikes.
Start with some documentation pictures and others can chime in with observations and guidance. Especially pictures of the "extra" parts!
Offline Chrispy56
« Reply #2 on: March 25, 2014, 06:57:34 PM »
This is what I am starting with. I found it for $200, I thought it was a good deal and a fun project.
Offline Trad
« Reply #3 on: March 25, 2014, 07:20:00 PM »
That thing looks pretty cool. Good luck with the build.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
« Reply #4 on: March 25, 2014, 11:47:03 PM »
The only specific failure item is the primary chain. selectors and gears can wear and some are not available.
A cheapish upgrade is a complete 550 motor which will drop in and bolt up you only need the R/H rear mounting plate as an extra from the 550 as the clutch cable stop is on it
Offline Chrispy56
« Reply #5 on: March 26, 2014, 04:38:18 AM »
Yes, I understand that is probably the best way to go. And I have been searching for a complete 550 motor.
Are the external components compatible between the 500 and 550? ie starter, intake and carbs(same size), points, etc.
I found a motor with about 10,000miles on it, but needs a little head work and mounts(including R/H rear mounting plate) for around $500 shipped. Worth it? Will the 550's more reliable bottom end give me the peace of mind I am looking for? I will go this route for reliability reasons only.
Offline Mo
« Reply #6 on: March 26, 2014, 07:33:15 AM »
$500 seems like a lot. You could buy an entire 550 project bike on craigslist.
Offline Chrispy56
« Reply #7 on: March 27, 2014, 05:57:14 AM »
I would settle for a 550 bottom end but can't seem to find one.
Offline Chrispy56
« Reply #8 on: July 11, 2014, 04:46:17 AM »
Finally found a 550 motor. I haven't seen it yet, but the guy says that it is "locked up".
Assuming that it is repairable, what is it worth?
And will the majority of my 500 internal component be compatible with the 550? ie crank, rods, etc.
Thanks
Offline calj737
  • I refuse...
« Reply #9 on: July 11, 2014, 07:22:56 AM »
Locked up motors are worth very little as you can not determine their damage. I'd pay max of $100. And for that, I'd want the carbs too.
There's some differences between the 2 lower ends, so mixing and matching can be done, but is tricky. You might be better off picking one, and fully rebuilding it. You could also get the 550, and see if you can "unstuck" it with some tricks floating around here (ATF/Acetone soak in the cylinders). Then you might be able to use it as an entire engine.
Pull the rocker cover and oil pan and give a decent look inside. Pull the side covers and clean/inspect it. Common for these motor to get stuck sitting, but come back to life with a bit of treatment. Worst case, you could pull the head and cylinders and have them machined up and re-used, and be off to the races!
Offline Chrispy56
« Reply #10 on: July 16, 2014, 05:36:13 PM »
Found a different 550 motor. Researching the serial number tells me its from a 77 f model. Its complete, turns freely, and came with the complete wire harness w/no cut wires. He also had the front section for the 4 into 1 exhaust including the finned clamps.
Offline nhg2112
    • CB500F Build Blog
« Reply #11 on: July 17, 2014, 07:51:15 AM »
I would get the 550 motor and build it from the best parts out of both. As mentioned earlier - the important bits of these engines are interchangeable. If the 550 turns and has good compression then pick the best carbs/pipes you've got and go forward from there. Keep in mind the carbs are unique to the intake manifolds so they need to stay together as a pair. The 500's, while cool and unique(ish), can suffer issues that really arent worth it (primary chain, clutch & transmission). If you end up having low compression, rings & a hone are an easy enough job - easily done in an afternoon if the engine's out of the bike.
I would also be very weary of a project that someone 'tore down and then half-rebuilt'. Best case you'll have to tear it back down and rebuild it making sure he didnt miss anything, worst case you blow up your engine after investing time & money to get it running. Once you've got a running 550 engine you can tear down the 500 engine and part it out - you could probably get 2-300 out of it that way, while learning about these awesome engines in the process.
Let me know if you end up parting out the 500 - I'll buy your transmission if the miles are low enough. I was stubborn enough not to do the 550 swap when I started my build  ;)
Offline Chrispy56
« Reply #12 on: July 17, 2014, 08:12:47 AM »
My 550 didn't come with carbs but my 500 did along with the manifold. But I can't find any numbers on the carbs so I can't confirm what they are. Where are the numbers located?
Offline calj737
  • I refuse...
« Reply #13 on: July 17, 2014, 08:23:35 AM »
Look on the body of the carbs, both sides, on all four. Can be hard to read at times. But they're on there in a small stamping. Post some pics, maybe someone can discern for you if you struggle to find them.
Offline nhg2112
    • CB500F Build Blog
« Reply #14 on: July 17, 2014, 11:08:23 AM »
This area right here. Check both sides
« Reply #15 on: July 20, 2014, 09:14:31 AM »
To put the 550 motor in you will need the R/H rear 550 engine mounting plate as it has the clutch cable mount on it
Offline Chrispy56
« Reply #16 on: July 20, 2014, 09:49:13 AM »
Yes, I received a box of parts with the motor, and found that piece in there.
Offline Chrispy56
« Reply #17 on: July 20, 2014, 10:28:08 AM »
I cant see any casting information on the carbs (other than Keihin Japan)
Also, two of the four towers where the main jets go look to be corroded. I have never worked with this type of carb, and was surprised to see that the main jets are held in place with orings the two corroded towers are barely holding them. Are these worth rebuilding.
size of main jets are 100, if that helps in identifying them.
Offline Chrispy56
« Reply #18 on: July 20, 2014, 04:41:23 PM »
The part number stamp was very light, but I did finally find it...its 627B. 71-73 CB500 Four.
« Reply #19 on: July 21, 2014, 01:06:52 AM »
The main jets should be held in with a leaf spring afair, the O ring just seals
Offline Schroeder
    • Schroeder Guitars
« Reply #20 on: June 17, 2016, 11:22:01 PM »
This is really interesting to read. I actually bought this bike from Chris and am in the process of rebuilding it with that 550 motor. Really glad that it was torn down when I got it. Learning a ton by going through manuals and seeing what is there and what is missing. A bit aggravating not having seen it come apart but it was fairly complete when I got it. Just getting into the carb rebuild now.
Roller with new bearings and seals, tires, etc.:
Pistons cleaned and rung:
Valves lapped and reinstalled.
Lots of oily dirt to clean up!
Guitar builder trying to re-build a bike...
1973 CB500k2 with 1978 CB550 motor
« Reply #21 on: June 19, 2016, 12:41:23 AM »
A favourite oil leak is from the oil pump cover and you need a 46 x 2 mm O ring to fix it (NOT a 500/550 part but if you can't get a generic one the Gold Wing uses that size) also if you fit any sort of O ring chain you will eat away the crankcases and that rubber blanking plug in front of the sprocket
Offline Schroeder
    • Schroeder Guitars
« Reply #22 on: June 19, 2016, 01:37:43 AM »
Thanks Bryanj. Ya there is a bit of wear on that oil plug from the chain. It appears to still be containing oil but we will see. I do have it on my list to rebuild the oil pump and put new runner in it. That seems to be a source of oil under the left side cover.  Thanks for the input.
