Author Topic: CB550 Switch Housing Paint Questions  (Read 1590 times)
Offline Chaser60
  • 75 CB550
« on: March 26, 2014, 05:34:57 AM »
I found an earlier post on a complete tear down and refurbishment of the left and right switches.   Unbelievably detailed and complete.   The switches I am working with are in good working order, but the overall color and finish on the outside is kind of all over the place.    See the pic below, including the master cylinder.  Pics dont show it well, but the top half is very different color than the bottom half on the switches.
I believe these were originally gloss black anodized. I don't really want to strip these completely down and remove all the springs, pins, "guts", but would like to get them back to gloss black and orange letters.   I have these off the original bar because I am going with the lower rise bar from CB400f.
So my questions are; Has anyone successfully masked and painted these switch housings, master cylinder and bracket parts?   What did you use to clean and paint?   Any tips on masking to keep over spray out of the electrical contact areas?
« Last Edit: March 26, 2014, 05:43:48 AM by Chaser60 »
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
Re: CB550 Switch Housing Paint Questions
« Reply #1 on: March 26, 2014, 06:20:36 AM »
Many years ago we used to clean up switches with Prepsolv, then spray with gloss auto lacquer.  When done, we would then use One Shot to wipe into the recesses.  One Shot isn't lacquer, so the mineral spirits used to clean away the extra off the lacquer didn't affect the finish.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline Bru-tom
« Reply #2 on: March 26, 2014, 11:19:15 AM »
polish em up ;D
« Reply #3 on: March 26, 2014, 12:00:30 PM »
dismantling them isnt as bad as you might think.
I did both of mine a few weekends back.  you'd be surprised at all the crud inside.
if you want to do a decent job, you'll have to take them apart.
I wire wheel'd mine to rough it up a bit, washed with acetone, etch primer coated and a few coats of gloss black.
sorry, no pictures with me of the tops.  but they turned out nice.
Offline Bru-tom
« Reply #4 on: March 26, 2014, 12:03:58 PM »
could one slap the entire assembly into an ultrasonic cleaner? that could make your job way easier. Then lube it up with dielectric grease afterwards...
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #5 on: March 26, 2014, 08:20:50 PM »
I just clean mine up real good with steel wool and wipe them down with mineral spirits.  You can disassemble or tape up the switches and buttons.  I have done it both ways.  Complete disassembly and cleaning is recommended.  I use Fil-Stiks to fill in the letters and just wipe off the excess.  It holds up well, comes in just about any color, is easy to use and is easy to repair if needed.  Just heat it up a little and it rubs right in to the recesses.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
« Reply #6 on: March 26, 2014, 11:00:03 PM »
id do the "RUN"in green and the "OFF"in red,seems more logical?
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #7 on: March 27, 2014, 03:34:23 AM »
Beware that rotary switch, if it's like the one I did, there's a little ball bearing beneath it. Have it over a cake pan when you disassemble to contain it. A speck of grease on it will hold it in place when you reassemble.
Agree on the disassemble if the action isn't crisp. Cleaning out the crud and contacts and lubing very lightly with silicone dielectric grease made mine work like new.
Great tip re the fil sticks. Will try that, seems easier than what I did. I've used model master paint, thinned and brushed in then squeegeed over top with a clean finger. For raised letters, a cigarette filter dampened with the same paint can be used well. Hold flat and dab till it's like you want.
Post pics!
I have a motorcycle problem.
Offline Chaser60
  • 75 CB550
« Reply #8 on: March 30, 2014, 06:12:03 PM »
Thanks everyone.   Will take them apart, clean and paint.   Have some other stuff to get done first so those side projects will have to wait a bit.
Offline Chaser60
  • 75 CB550
« Reply #9 on: March 30, 2014, 06:44:45 PM »
That would be awesome and I sure owe you some paybacks from all the help and advice.  However...I am still not recovered from the "works" toilet escapades in the tank to get that rust out...I think I am done with chemicals for a while.  So ready to start turning wrenches and screwdrivers.
