Author Topic: What does the adjustment bolt at bottom of clutch cover do?  (Read 2365 times)
Offline kippstakes
« on: March 26, 2014, 02:43:55 PM »
Been having some trouble with my clutch grabbing when my cb550 76 is hot lately. Trying to stab it from all angles. Clutch plates are in good shape, cable is new, etc.  Wondering what the bolt at the bottom exterior of the clutch cover does. I know it adjusts the rod that engages/disengages the clutch, but what happens if I adjust it in/out?
Thank you
Strength is just an accident arising from the weakness of others.
-J. Conrad
Offline LesterPiglet
  • 1977 CB550F2
Re: What does the adjustment bolt at bottom of clutch cover do?
« Reply #1 on: March 26, 2014, 02:53:09 PM »
It messes up your clutch unless you turn it whilst reading the manual.   :D
Offline sixthwisconsin
  • With an 1855 Springfield, I'm a
« Reply #2 on: March 26, 2014, 04:31:54 PM »
LOL!!
Offline toytuff
  • "watching the pinheads"
« Reply #3 on: March 26, 2014, 04:34:31 PM »
We'll, enough said.
tt
Offline kippstakes
« Reply #4 on: March 26, 2014, 05:28:02 PM »
I shall refer to the manual, in that case.
-J. Conrad
  • 1977 CB550F2
« Reply #5 on: March 26, 2014, 05:39:14 PM »
That screw is the first thing in the clutch adjustment procedure. If it isn't set properly you will never get a good lever. Best to aquaint yourself with the manual, it explains it better than I could.
Offline lucky
« Reply #6 on: March 27, 2014, 07:42:19 AM »
So many questions and problems could be solved by reading your manual.
Forget your phone.
Offline kippstakes
« Reply #7 on: March 27, 2014, 02:36:30 PM »
Would the lever cause the clutch to not close/lock completely?
Will crack open the manual tonight.
-J. Conrad
  • 1977 CB550F2
« Reply #8 on: March 27, 2014, 03:22:22 PM »
Bad clutch adjustment would cause this. Whether it is at the handlebar, the mid-cable or the adjuster on the casing. You need to work from the bottom up. Yes read the manual.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #9 on: March 27, 2014, 03:36:26 PM »
Great. Now my office mate is looking at me funny and wondering why I shot iced tea out my nose. Thanks Lester.
I have a motorcycle problem.
Online dave500
« Reply #10 on: March 27, 2014, 09:44:11 PM »
that primary adjustment isnt terribly critical,your supposed to have the cable slackened of and with upward thumb pressure on the lever adjust the screw untill those two dots line up,then re-adjust the cable to fine tune it or to how you like it,often youll need to adjust the primary again on an older or used clutch to get it to release properly or to not slip and the dots wont be lined up once its sorted,counter clockwise on the screw gives less bite and more slip and starts the disengagement sooner and visa versa,counter clockwise aids release if you have a grabby cold clutch,clockwise might help if its slipping,if you cant get a happy medium youll need new friction plates and deglaze the steels,also check the baskets end float.
« Last Edit: March 27, 2014, 11:54:24 PM by dave500 »
Offline kippstakes
« Reply #11 on: March 29, 2014, 05:54:31 PM »
Thank you, Dave. That's what I'm looking for. Advice noted.
-J. Conrad
Offline kippstakes
« Reply #12 on: March 29, 2014, 10:11:02 PM »
Strange thing is that the clutch isn't slipping, in fact it's quite the opposite. The clutch will engage smoothly but only until the bike gets hot, then the clutch begins to grab as if multiple plates are engaging at once. It makes the bike an absolute chore to ride and pisses me off smartly. The hotter the bike gets, the worse it grabs. Getting off the line at stop lights in first gear is unpleasant and takes a delicate touch, to put it mildly. The problem has persisted over two clutches, as I replaced the entire basket, including all plates a while ago. It's very strange and I'm not sure what to make of it.
Any ideas?
-J. Conrad
Online dave500
« Reply #13 on: March 29, 2014, 10:55:39 PM »
if its an old cable it might need replacing,try lubing it,they should run so free as to have minimal friction,unless its routed wrongly?
Offline kippstakes
« Reply #14 on: March 30, 2014, 11:51:37 AM »
both push and pull cables were replaced a few months ago, so they should be fine. pretty sure routing's good, no hard turns.  how do you get lube through the cable? is there a trick?
-J. Conrad
Online dave500
« Reply #15 on: March 30, 2014, 12:23:03 PM »
?the clutch only has one cable,the throttle has push/pull cables?
Offline kippstakes
« Reply #16 on: March 30, 2014, 07:17:48 PM »
Of sorry, was picturing the wrong thing in my head. The clutch cable was replaced at the same time, did them all in one day.
-J. Conrad
