Author Topic: Nuetral light switch  (Read 1269 times)
Offline topgun
« on: March 27, 2014, 12:48:49 AM »
Hi Guys, I have fitted a new neutral light switch brand new from CSML and when I tighten it up it will not change gears if I back the bolt off it will change gears, it,s like the switch is binding on shaft have fitted new o,ring as well, no problem changing gears before swapping switch, Any help would be appreciated Cheers Tony
Offline rklystron
  • I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
Re: Nuetral light switch
« Reply #1 on: March 27, 2014, 02:38:17 AM »
2 thing come to mind. 1 Check to make sure the ball at the end of the switch retracts. Sometimes they can bind. The other is make sure you are in neutral when you install. The shift drum may not be aligned properly. It can move in and out a bit. Making sure it is in the right position is important. I hope this helps you some.
1970 CB750 K0 (Bought in 73)
1972 XL250 (Bought new in 72)
1973 ST90 (Free)
1975 XL250 (Free)
1975 Rickman CR750
1982 CBX1000 Pro-link
1975 CB750 DRAG BIKE
1977 Custom Built CB750 Sturgis Bike (GL front end).
1977 CB750 F2 (Big Resto)
1977 CB750A (Auction Buy)
1978 CB750 K8 (My San Francisco ride)
1984 VFR750 (Bought New)
Offline topgun
« Reply #2 on: March 28, 2014, 12:51:29 PM »
Thanks for your input still having issues have tried nearly everything doing my head in lol
« Reply #3 on: March 28, 2014, 01:16:41 PM »
do you still have your old switch to compare dimensions?
it might be that its too long and jambs up the shift drum/neutral indention
how about adding a washer shim between the switch and the o-ring/lower case?
you can always modify the retainer clip/screw to fit if the shim works.
Offline yesteryear
  • Long Live Rock n Roll
« Reply #4 on: March 29, 2014, 11:19:58 AM »
If its the genuine article make sure shes is in neutral and it should fit straight in no problem.Done it loads of times and I have had no problems.The only trouble I have ever had is with Pattern CRAP.
Cheers
Yesteryear
Offline topgun
« Reply #5 on: March 29, 2014, 08:40:26 PM »
Thanks for your feedback guys, after a few more goes I gave it a smear of grease all over and it went in and bolted up no trouble, might have been a bit of a lip on the selector shaft or maybe I was holding my tongue just right lol Cheers Tony
Offline wjustinleigh
« Reply #6 on: March 30, 2014, 10:30:17 PM »
My solution to my neutral light issue is to let out the clutch.  If it tries to go it's in gear, if not, neutral.
71 cb500
72 cb500
07 Bandit 1250
Offline atm cycles
« Reply #7 on: March 31, 2014, 04:55:23 AM »
Topgun glad to hear you got it to seat. When removed there is some end play in drum. Picked up a real nice k6 750 once put it on the road right away. Never made it to the gas station mile from home first time out!! Long story short.broken dogs bent shaft all because PO didn't seat neutral switch. Spaced bolt with washers!! After splitting cases and installing new trans putting it back together turned out to be a great bike.
