Author Topic: 1973 CB750 Custom Build on Hack A Week  (Read 102984 times)
Offline mystic_1
  • 1970 CB750K
Re: 1973 CB750 Custom Build on Hack A Week
« Reply #175 on: January 24, 2016, 01:11:31 PM »
Ah, that smile when it first fires up after months of labor.  Nothing quite like it.
You will be on the road soon!
I may have missed if you said this already but are you planning on any electrical system upgrades or just putting it all to stock at first?
cheers
mystic_1
- John Augustus Shedd
Offline disco
« Reply #176 on: January 24, 2016, 01:37:57 PM »
Hi Dino,
Greetings from Australia! Been watching your video series. Great to see the CB750 fire up. I was especially interested to hear the Delkevic exhaust as I also recently purchased one for my CB750 project bike.
I did notice around the 2:12 mark that you have some rust holes which have perforated the frame brackets near the rear engine mounts. You might want to check that out a bit further before taking it onto the road.
btw you've got an early model head there.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline mystic_1
  • 1970 CB750K
« Reply #177 on: January 24, 2016, 02:50:01 PM »
Oh hey good catch disco!
I went back to episode 1 and they seem to be visible right at the 10:20 to 10:30 marks there too.
Dino, tap those areas with a hammer lightly to see if the metal is sounds.  It looks to me like the holes were painted over.  I'd at least throw some silicon or something over those before riding it to avoid ingesting any water there, that'll rot out the frame lower tubes eventually.
mystic_1
Offline Dino
    • HackAWeek
« Reply #178 on: January 24, 2016, 06:29:32 PM »
Thanks guys. I have noticed those holes before. The frame is powder coated. I'll plug those up with some urethane windshield sealant. Tougher than silicone and it doesn't promote rust like silicone does. The acetic acid in silicone is the culprit. I learned that from a guy that installs windshields.
The bike is a 1973 so yes, the head has the early exhaust flanges.
If it ain't broke, don't fix it!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #179 on: January 25, 2016, 07:11:16 AM »
Congrats, Dino!
Your videos were an AMAZING help last year when I did my head gasket, and will be again this year when I do my forks.
Congrats on the startup!
--Evan
1975 CB750K "Rhonda"
Offline Dino
    • HackAWeek
« Reply #180 on: January 25, 2016, 03:11:02 PM »
Congrats, Dino!
Thanks! Just be sure to pay attention to which way that fork seals go in. The notch goes down! I made a mistake in the video and added an annotation to correct it. I still need to pull my seals out and flip them over. :)
« Reply #181 on: January 25, 2016, 03:17:55 PM »
Congrats, Dino!
Rule of thumb (with no known exceptions) The open side of seal goes towards the oil.
Offline evanphi
  • Apparently I'm an
« Reply #182 on: January 26, 2016, 05:46:08 AM »
Congrats, Dino!
Good to know. Adding this to my "notes" for the project!
--Evan
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=bju5l2va0i09363bjgmlfbg1m7&/topic,60973.0.html
« Reply #183 on: January 26, 2016, 06:11:41 AM »
the sealings have dubbel lips..so think they can Work both vays..but still right is right..and vrong is vrong...even it vorks...as two tire oftes said...
i hate all this v-w.... vords
« Reply #184 on: January 26, 2016, 10:25:04 AM »
If they don't leak then they are not installed improperly  ;)
Offline Yozzer74
    • Yozzer
« Reply #185 on: February 01, 2016, 12:38:52 PM »
Hi dino congratulations on getting bike running your videos have been a great help to me especially when rebuilding my top end .Just like to say thanks for taking the time to do them .
Offline Dino
    • HackAWeek
« Reply #186 on: February 07, 2016, 04:26:09 AM »
I got a good start on the electrical system this weekend. Any suggestions on proper routing of the harness are appreciated. Also, does anyone have info on those other rectifiers that I have in the spare parts box? I'm assuming that they are an upgrade to the stock part and would offer a little more current flow.
Offline mystic_1
  • 1970 CB750K
« Reply #187 on: February 07, 2016, 04:51:25 AM »
This should help
mystic_1
Offline pipeguy
« Reply #188 on: February 07, 2016, 05:11:35 AM »
Dino I just used your shifter assembly video it was awesome! And congrtas on first start up!
1970 CB750 K0
1980 CBX
2001 Electra Glide
2013 CRF450R
2013 KX450F
1977 KH 400 triple (gone)
1973 CB750 K3 (waiting it's turn)
2000 KLR 650(gone)
2001 BMW 1200RS(gone)
2004 Busa limited(sadly gone)
2003 ZZR250 ninja(gone)
1996 VFR750(gone)
1974 RD350(really sadly gone)
Offline Restoration Fan
  • My wife will never call me
« Reply #189 on: February 07, 2016, 05:17:07 AM »
Just watched the video earlier.  Nice job yet again, Dino!
Offline grepper
  • Busted Knuckles
« Reply #190 on: February 07, 2016, 06:06:14 AM »
Good stuff, went through this process two years ago.  A lot of my stock electrical bits were in rough shape and I went as far as disassembling the plugs, soaking the terminals in vinegar, cleaning,  reassemble with a dab of dialectic grease before plugging together.  Not sure what after market harness your using, but I have found them to be a bit generic.  You might have extra wires in the headlight bucket that don't go to anything.  I struggled with it for quite some time before I read about it here.
Offline Dino
    • HackAWeek
« Reply #191 on: February 07, 2016, 06:49:02 AM »
Thanks for the help guys! That diagram is perfect mystic_1!
« Reply #192 on: February 07, 2016, 06:51:23 AM »
Dino,
Is the other rectifier is likely a solid-state regulator rectifier unit?  If so, it's a solid improvement over the stock parts.
« Last Edit: February 07, 2016, 06:53:07 AM by CB750 Cafe Racer Fan »
« Reply #193 on: February 07, 2016, 08:56:39 AM »
How many wires and what color come from your extra electronics?
Offline chewbacca5000
  • I polish covers!
« Reply #194 on: February 15, 2016, 07:04:15 PM »
You would think the solid state regulator would be an improvement, but that is not necessarily   true.  The original unit has a points gap that allows you to fine tune the voltage output.  The stock electrics are fine for most applications.  If use a led headlight you will be in the energy surplus.  Too bad you can't   sell it back to the grid. Ha,ha,ha
Offline Dino
    • HackAWeek
« Reply #195 on: March 05, 2016, 07:45:52 AM »
OK quick question. I'm working on the final phases of installing the wiring on the CB750K3 today. Since I didn't take the bike apart, I'm having to source pictures to determine where the wires route on the bike. I have most of it sorted out but I'm curious if anyone knows what the proper routing is for the ignition wire loom that come from the points? Does it go under or over the engine? I know where it joins to the main harness.
Any advice is most appreciated. :)
« Last Edit: March 05, 2016, 07:54:02 AM by Dino »
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #196 on: March 05, 2016, 07:59:53 AM »
Well, under, sort of.  There should be a bendy clip held on by the corner screw on the bottom/rear of the case (very near where that wire comes out of the hole by the points) and then it goes along that side/bottom area and above the oil line hookups on the case. It then turns in behind the oil tank and connects.
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #197 on: March 05, 2016, 08:43:52 AM »
Awesome videos on your CB750 and Sabre V45 bikes.  ;D
« Last Edit: March 05, 2016, 09:09:16 AM by Artfrombama »
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline Dino
    • HackAWeek
« Reply #198 on: March 05, 2016, 09:01:44 AM »
Thanks guys! :) You just got a shout out on this week's video.
Offline mystic_1
  • 1970 CB750K
« Reply #199 on: March 05, 2016, 10:16:47 AM »
This may help.
mystic_1
