Author Topic: 1973 CB750 Custom Build on Hack A Week  (Read 107218 times)
Offline Dino
    • HackAWeek
Re: 1973 CB750 Custom Build on Hack A Week
« Reply #50 on: January 17, 2015, 12:05:27 PM »
Hey everyone... been a while.
I'm finally getting back to work on the CB750 project after a garage remodel. New work bench, big ass tool box at home now, more shelves for storage, better lighting. I'm trying something different with the connecting rod/piston/cylinder install. Doing it upside down with the bottom of the case removed.
« Last Edit: February 14, 2015, 04:28:53 AM by Dino »
If it ain't broke, don't fix it!
Offline Dino
    • HackAWeek
« Reply #51 on: January 19, 2015, 04:31:19 AM »
Part 14... upside down piston/cylinder/connecting rod install.
« Last Edit: February 14, 2015, 04:28:35 AM by Dino »
« Reply #52 on: January 19, 2015, 09:54:33 AM »
Great videos, Dino.
Offline Riceman
« Reply #53 on: January 19, 2015, 11:44:17 AM »
Nice!, didn't have too wait to long for #14... :)
I had to go back to # 5? to figure out that a locking
nut was not needed on top of the bearing seal nut
on the fork stem...
Offline Restoration Fan
  • My wife will never call me
« Reply #54 on: January 19, 2015, 12:49:58 PM »
I posted a comment under the YouTube video, but it may have been easier to use a bottle jack to raise the head up.  The way you did it was pretty ingenious with the little tubes to screw on but I would have gone with the "lazier" method of using a bottle jack and a piece of wood to slowly lift the head up onto the studs.
Offline persson-johan@hotmail.com
« Reply #55 on: January 25, 2015, 11:47:13 AM »
Great videos! Been watching all of them :)
Offline Dino
    • HackAWeek
« Reply #56 on: January 26, 2015, 02:40:10 PM »
Crankcase goes together.
« Last Edit: February 14, 2015, 04:28:17 AM by Dino »
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #57 on: January 26, 2015, 06:26:43 PM »
The back on my K5 case has 2 bolts that get nuts on them...I don't have a third one like you talked about was missing. Interesting...
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline Dino
    • HackAWeek
« Reply #58 on: January 31, 2015, 05:47:05 AM »
« Last Edit: February 14, 2015, 04:27:58 AM by Dino »
Offline BPellerine
« Reply #59 on: January 31, 2015, 09:40:43 AM »
I think that you need those oil jets to maintain pressure.bill
1978 CB 750K ard and webers
another anfob
« Reply #60 on: January 31, 2015, 09:44:22 AM »
True. Withou oil jets the bottom will starve and kill crankshaft bearings.
« Reply #61 on: January 31, 2015, 01:05:38 PM »
yep...not an optional part.  Also, it's pretty much universally accepted that the cam tower pucks will leak prematurely without some Hondabond or other non-hardening sealer.
Offline Dino
    • HackAWeek
« Reply #62 on: January 31, 2015, 01:55:41 PM »
Thanks guys. I'm searching for those oil metering jets so when I take the cam holders back off I'll add Hondabond to the pucks.
Offline Mikey S
« Reply #63 on: January 31, 2015, 06:19:44 PM »
Been enjoying the vids for a long time Dino. Loved the Sabre build, and really excited to see you work on an orange '73 for obvious reasons. Thanks for all of the ingenious tips you've given me over the years.
« Reply #64 on: January 31, 2015, 06:30:38 PM »
The oil jets are long discontinued and hard to get used 'cuz guys always lose them...measurements are posted here on the forum somewhere and can be made on a lathe.  One recent poster on this thread can do it! :o  I will let him speak up if he wants.  He may not be wanting to mess with it...
Offline BPellerine
« Reply #65 on: January 31, 2015, 06:43:39 PM »
member dhoulton in services offered.bill
another anfob
Offline AintNoEasyWay
« Reply #66 on: January 31, 2015, 09:21:08 PM »
Here's a fairly recent thread I had about oil jets: http://forums.sohc4.net/index.php?topic=142986.0
Lots of people chimed in.
Offline Dino
    • HackAWeek
« Reply #67 on: February 01, 2015, 05:27:04 AM »
Thanks guys. I've consulted Hondaman via PM and he said they have to be in there or bad things happen to the main bearings very quickly. If I had the dimensions and hole sizes I'd just make some on a lathe.
EDIT: I found the drawing of the oil metering jet that Hondaman posted so maybe I'll try making some. :)
« Last Edit: February 01, 2015, 06:01:38 AM by Dino »
« Reply #68 on: February 01, 2015, 05:44:11 AM »
Dino,
Love your videos.  Been watching them for quite some time on other stuff as well.  Here's a link to a thread where HondaMan gives those dimensions & hole sizes.  Has the technical drawing in it.
http://forums.sohc4.net/index.php?topic=134855.msg1515632#msg1515632
« Reply #69 on: February 01, 2015, 08:56:08 AM »
It is not that hard to make oil jets, HM drawing is from what I understand on the smaller end of metering hole, the hole was bigger in later production years.
Check out the service offered section.
Offline Dino
    • HackAWeek
« Reply #70 on: February 07, 2015, 01:58:20 PM »
Mike Rieck sold me two metering jets. Thanks Mike!
I got the shifter assembly together today. One step closer to a completed engine.
« Last Edit: February 14, 2015, 04:27:34 AM by Dino »
« Reply #71 on: February 07, 2015, 07:09:17 PM »
Dino,
Kicking this project into high gear - no pun intended!
« Reply #72 on: February 09, 2015, 07:45:54 AM »
Really great job showing not only assembly but how the shifting is accomplished.
Offline Dino
    • HackAWeek
« Reply #73 on: February 14, 2015, 04:26:59 AM »
Oil pump got installed this week. It was in good shape and only needed the usual o-rings. A few viewers have mentioned that I should have primed it before installing it but I'm thinking that could be done via the oil inlet fitting. I guess I'll find out when the time comes.
Next week I'll get the oil metering jets installed along with the camshaft and rocker arms.
Offline mystic_1
  • 1970 CB750K
« Reply #74 on: February 14, 2015, 07:15:28 AM »
No need to prime the oil pump on a 750, gravity feed from the tank will take care of that on startup.  I've never primed an oil pump on a 750 and never had a problem.
Kick the engine over a few times or crank the engine over with the kill switch turned off prior to firing it up for the first time, and you should be ok.
BTW the leak stopper valve keeps oil from running down from the tank into the motor when the motor is not running.  If it's not working, the tank will drain down into the engine sump over time and the oil level in the tank will be low before startup, then return to normal after startup.
mystic_1
« Last Edit: February 14, 2015, 07:31:41 AM by mystic_1 »
- John Augustus Shedd
