Author Topic: CB750 Engine/Carb Compatability  (Read 649 times)
Offline Accolay
« on: March 30, 2014, 01:10:16 PM »
Getting back in the saddle again. Want to start finishing the backlog of projects.
I have a 1977 CB750 rolling frame with title, missing the engine/carbs/airbox and I think I have a K4 engine from the serial number: 2356323
Just wondering if the engine will fit and if so what carbs will I need? Haven't really decided if I should either sell it and spend time with something else or start buying parts.
Thanks.
1977 CB550F
Offline Old Scrambler
Re: CB750 Engine/Carb Compatability
« Reply #1 on: March 30, 2014, 05:45:27 PM »
Motor will slide right in......but you will need the off-set sprocket (Cycle-X) to match your chassis........standard 28mm carbs...........you may have to play with the fuel-rail depending on which side of the tank fed the carbs.  Standard air-box........but try to get a 77-78 for the best air-intake.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: March 30, 2014, 07:05:56 PM »
I have a 78k motor in a 75 frame.  Old Scrambler has it right on the Cyclex offset sprocket.  You can also mix and match the 77/78k sprocket carrier into the earlier wheel with the correct mix of spacers.  Chain to rear shock clearance is very tight, so any shock that is bigger in diameter than the stockers in the path of th chain is going to require further mods to work.   As far as carbs, any will work but you have to have the correct carb and airbox boots...77/78k pd carbs require different boots than the '76 and earlier roundtop carbs.
« Last Edit: March 30, 2014, 07:08:25 PM by seanbarney41 »
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #3 on: March 31, 2014, 04:25:28 AM »
So if I have a 75k engine in a 77K, I will need this sprocket as well?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #4 on: March 31, 2014, 05:10:20 AM »
I have a sprcket from a 78 motor...would that bolt on if I do need an adjustment?
Gus, Austin, MN.
« Reply #5 on: March 31, 2014, 06:24:38 AM »
you will need to use the sprocket carrier(or entire wheel)from a '71-'76 k model and maybe custom wheel spacers?  The Cycle X sprocket page has pictures and explains this pretty well...
http://www.cyclexchange.net/Chain%20Sprocket%20Page.htm       down at the bottom of the page
also search here, there are several old threads on this
