Author Topic: My $75 Supersport Resurection  (Read 9512 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: My $75 Supersport Resurection
« Reply #25 on: April 02, 2014, 06:41:00 PM »
It shouldn't need much ass. The chokes should rotate smoothly. Lube the shafts and check the motion of the choke plates for any resistance. Check that the spring appears to engage both components. Look for anything that might be bent or loose.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline What2007
« Reply #26 on: April 02, 2014, 07:02:28 PM »
I'll bring the whole thing in to work tomorrow and see what I can do to loosen everything up.
Offline What2007
« Reply #27 on: April 03, 2014, 06:17:45 PM »
Choke is still acting up, but it's a little better. Ordered new cables and such.
Trying to get this damn thing started is driving me nuts. I can get it run off of ether, but no luck just on gas. I'll go through them again and if I can't get it this weekend I'll just have them rebuilt.
« Last Edit: April 03, 2014, 06:42:38 PM by What2007 »
Offline What2007
« Reply #28 on: April 09, 2014, 07:11:52 PM »
Got her to fire up tonight. It'll only stay running if I fiddle with the choke though. I have the needle at 2 turns so I'm going to put it at the 1.5 I keep reading about and try it again. Also going to need new bowl drain plugs as all 4 of them leak now since I cleaned everything.
Offline What2007
« Reply #29 on: April 10, 2014, 05:19:54 PM »
Here's a video. Little smokey. Still need to do some carb adjustments.
Offline What2007
« Reply #30 on: April 12, 2014, 02:59:45 PM »
Put on some euro bars. Kind of wish I had a longer clutch cable. Broke my choke assembly in the process unfortunately.
« Reply #31 on: April 13, 2014, 10:51:12 AM »
Nice bars.
Offline What2007
« Reply #32 on: April 18, 2014, 07:42:51 PM »
Could somebody please tell me how to route these breather lines?
Offline colvinry
« Reply #33 on: June 14, 2014, 11:08:45 AM »
What2007 could you take some more pics if the carb mechanism,  I cannot figure mine out. I took my carbs apart for cleaning and rebuild and am having trouble getting the carb cams to link up properly. An pics or advise will help.  Here is a pic of where I am at. It is close but I feel like I am doing something goofy.
