Author Topic: CB550 Master Cylinder Corrosion - Should I change this?  (Read 456 times)
Offline Chaser60
  • 75 CB550
« on: March 30, 2014, 06:06:36 PM »
When I took the bike off the road in the fall, the brakes were working fine.  Not Spongy.   This photo shows inside and some kind of discoloration or corrosion.   Should I clean this up, leave it alone or replace it?   If it should be cleaned up, how did you do it?
Appreciate the advice.
