Author Topic: f2 barrels on k3 motor  (Read 1046 times)
Offline kezz32
« on: April 02, 2014, 02:45:11 PM »
this may well have been covered before.. just been offered a mint set of f2 pistons and barrels.. will they fit a k3 motor.?. i have two k motors and these would make good spares if they are compatable.
kezz
Offline BPellerine
Re: f2 barrels on k3 motor
« Reply #1 on: April 02, 2014, 07:09:20 PM »
think you have to have the f2/f3 head as well to use the barrels.bill
1978 CB 750K ard and webers
another anfob
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: April 03, 2014, 04:11:12 AM »
The barrels will work.... sort of. You may see some restricted flow at four of the oil returns through the F2 barrels. The F2/F3 only used four oil returns while the early K barrels used eight:
Also, I believe the F2 pistons had a higher dome since the F2 heads used a taller combustion chamber. You would need to verify clearance between the F2 pistons and the K3 head.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
