Author Topic: oil tank fittings  (Read 1227 times)
Offline turboguzzi
oil tank fittings
« on: April 03, 2014, 07:05:07 AM »
not directly sohc 4 but is there a better place to ask? :)
building the oil tank for the supermono and need a source for metric fittings to connect it. preferably in europe / UK for tax shipping costs.
also some advice on size.... most likely will weld cylindrical bungs with thread to the tank so need to know diameter. shall i plan M14 thread then?
And yes, gonna have some thermal insulation on top, last thing i want are well done family jewels!
Re: oil tank fittings
« Reply #1 on: April 03, 2014, 08:07:24 AM »
You may want to run AN fittings, easy to run braided lines.
 Steel tank, or aluminum?
If Aluminum, get weld on bungs. Cutting the thread off a fitting forged from 7075, can be VERY messy to weld.
Offline Tintop
« Reply #2 on: April 03, 2014, 08:21:46 AM »
+1 on weld on aluminum bungs & AN fittings.  Aeroquip or Earl's should be readily available, and can supply the bungs, fittings & hose.  You'll also need to include a breather for the tank that goes to a catch tank.  AN6 would be a minumum hose size, AN8 likely better for a racing application.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline turboguzzi
« Reply #3 on: April 03, 2014, 09:08:58 AM »
ally tank, and yep, welded on bungs for Dash 8 hose or some sort of metric equal.... but was thinking metric cause i am in italy and most likely the guy that does my tubes/crimping will have metric tubing. So anybody this side of the pond has links to shops?
Not a big fan of SS braided (unless for brakes), all my oil-air GSXRs have the stock fabric braided hoses under pressure and they never failed even after 25 years :)
it's quite a convoluted way from motor to the rear mount tank, so I want the extra flexibility of fabric braid.
it's a low pressure application anyway. one side is negative pressure, the other expels to atmospher  pressure.
while at it, what do you guys use for a filling plug? M22 should do i'd think...
« Last Edit: April 03, 2014, 09:34:27 AM by turboguzzi »
« Reply #4 on: April 03, 2014, 09:55:53 AM »
I made some bungs that take a tappet cover.
Offline Tintop
« Reply #5 on: April 03, 2014, 10:56:15 AM »
Here's the link for Aeroquip in Italy TG - http://www.moeller.it/
They do have a 'fabric' covered hose, Startlite that I used on my 550.  It's more flexable than the SS wrapped.  As for a 'filling' plug, why not just use a threaded cap, and bung.  Alternative Aeroquip has large size plugs with an o-ring seal, just need to safety wire.
77 CB550 Cafe build
Offline turboguzzi
« Reply #6 on: April 03, 2014, 03:03:37 PM »
tnxs for the info guys... for the cap, i will go with the largest thread i have in my set tap set, M18 X 1.5 looks big enough to top up when needed
will look up the startlite tube....
