Author Topic: esr240 wiring...anyone found it out?  (Read 954 times)
Offline dohcdelsol93
« on: April 03, 2014, 05:14:17 pm »
half of this flipping thing is plug and play...the other half...not so much.
There are two spade ended wires that dont' match up with hondas color code.  Its the green and the brown on the ESR240  unit.
They are supposed to plug in where the voltage regulator go.  However the regulator has a green, white and black wire.
The stock honda regulator uses a black, white and green wire.
I've done numerous searches and seems no one on this board has identified and documented this issue.
any help would be great...with my daily driver down this bike is my only commuter.
i'd rather be sailing
Offline Airborne 82nd
Re: esr240 wiring...anyone found it out?
« Reply #1 on: April 03, 2014, 05:16:37 pm »
ESR240  unit. ??? Don't know what it is or who makes it.
Offline LesterPiglet
  • 1977 CB550F2
« Last Edit: April 03, 2014, 05:23:50 pm by LesterPiglet »
« Reply #3 on: April 04, 2014, 11:10:15 am »
http://forums.sohc4.net/index.php?topic=90786.0
that was exactly what i needed!  Thanks a ton
13+ volts over 2500 rpms!
I'm glad i don't have to ride with a spare charged battery in my pack anymore.
Offline sanxa_
« Reply #4 on: September 17, 2014, 06:41:23 pm »
Can you tell me how you solved the brown & green connections? I read through the other threads and the search results but still can't figure out what to do.
'73 Honda cb350f (project)
'78 Kawasaki kz200
Offline sanxa_
« Reply #5 on: September 17, 2014, 06:47:01 pm »
Am I right in understanding brown to black and green to white?
'78 Kawasaki kz200
