Author Topic: Another overkill tool build  (Read 5619 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
Re: Another overkill tool build
« Reply #25 on: September 18, 2006, 12:39:12 AM »
I think some of the hospitals in southeast asia still use IV drippers that look like
that....not sure about the pressure pump though.  ;D
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #26 on: September 18, 2006, 02:40:37 AM »
cbj: i bought mine from my local m.c. shop for $30. if they're selling them for that retail, they've gotta be out there on the web for cheaper...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline jgary
    • Catholic Nature Cards
« Reply #27 on: September 18, 2006, 06:43:19 AM »
I used this contraption this past weekend, and had a learning opportunity.  The metal line coming into the caliper has to be the highest point in the caliper when pressurizing, otherwise a little tiny bit of air can still get trapped in there.  Either that or use more air pressure.  Even with that little hitch, this was still a lot easier than what I've done in the past.
John.
1972 CB 750
1976 CB 750
DeLuxe
« Reply #28 on: September 18, 2006, 06:45:22 AM »
Hey J, love the pressurised bleeder!
I 'reverse bleed' but with a big syringe that I was given free with a bottle of Motul Dot 4 at my local. It's only about 150ml, but it's enough to fill the whole line on my CB400f (I have a custom braided line) and the master cylinder, which is off a Spada - ( same MC as on a CB250R). I guess it would cost about $2 to buy one at the chemist.
I hate to think what they use that syringe for medically...ouch!
Boomologist
« Reply #29 on: September 18, 2006, 07:09:52 AM »
I did build one that I saw on the net a few years back. It was simply a jar with colored water, 4 tubes that ran up a board and back down to the engine. It worked good. My shop is heated with wood so it goes below freezing on most winter nights. So I decided to fill it with antifreeze. Next time I used it I made the mistake of reeving the engine and closing the throttle. It sucked antifreeze up the tubes and into the engine! Not good.
Incidentally, the board these tubes ran up was 8 feet long.
I now have the style filled with Mercury and it does a nice job. What is really nice about this style is that you have the tubes for all four cylinders mounted side by side so it's easy to get them exact.
I also acquired a couple of the style that you hold over the carb throat and read a small ball that rides up a tube. These also seem to work good but the best is the mercury, in my opinion.
« Last Edit: September 18, 2006, 07:16:05 AM by Boomologist »
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #30 on: September 18, 2006, 04:32:44 PM »
Here are some pics of a carb balancing tool I built with some aquarium tubing, "T" connectors, tape, a paint stir stick and some water dyed with food color.  I have less then $5 into it so far.  I haven't used it yet as I'm trying to find the right nipples to screw into the vacuum ports.  Anyone know where I can find some nipples with 6x0.8 threads?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline mwohlenhaus
« Reply #31 on: September 18, 2006, 04:44:54 PM »
you wanna screw silencers onto the ol nipples?!?! ;D seriously though, I have no clue.  could you use a presse in tube made of brass, or something to that effect?
« Reply #32 on: September 18, 2006, 06:49:08 PM »
Hmmmm I wonder if the valve fittings from the kit with the T connectors would seal tight 'nuf.  I'll give them a try!
Sure.
Is it hard?
Offline Klark Kent
« Reply #33 on: September 18, 2006, 08:21:01 PM »
a friend of mine had sticks with no adapters so i was looking for a hardware company that could supply 5mm to hose barb adapters.  my friend found the adapters before i ended up doing it, but they said they could order them from a company called airpro "in europe."  ive never heard of an airpro that makes brass fittings.  they also said they would cost $4.20 a piece and the next order was going out in two weeks.  so that would screw up your low-budge effort.  the place i found was called maryland metrics, and you may have a similaar hardware source near you.  hopefully they can get them to you cheaper and faster than maryland metrics said they could.
-KK
-KK
75 CB550k
95 KLR650
www.blindpilotmovie.com
download the shop manual:
you'll feel better.
listen to your spark plugs:
« Reply #34 on: September 18, 2006, 09:19:04 PM »
you are right, they are 5x0.8mm nipples.  See this thread.
http://www.sohc4.us/forums/index.php?topic=13511.0
Sure.
Is it hard?
Boomologist
« Reply #35 on: September 19, 2006, 11:44:05 AM »
It wouldn't be too difficult to take a 5mm bolt, cut the head off, and drill a small hole through it. Just be sure to use a bolt that isn't threaded all the way to the head so you will have a smooth surface to push into the tube.
