Author Topic: Issue  (Read 1072 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Issue
« on: April 05, 2014, 07:40:40 PM »
So I lifted up the tank on my bike and saw this. Ive now owned it for a few days and its been one bummer after another. Now I see someone has cut the frame! How bad is this?
Sent from my PC36100 using Tapatalk 2
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Re: Issue
« Reply #1 on: April 05, 2014, 09:20:06 PM »
That's what we used to call, "very serious".  :-\
Without the 2 triangle support tubes, there will be LOTS of side-to-side and twisting motion imparted by bumps, let alone lean-over angles in turns. I would imagine it to feel like it has a mind of its own?
You can insert some mild steel tubes and just weld them in place: they are not a fancy shape or anything like that. They just go straight from the cut-off holes at the back to their matching cut-off holes in the front, and there is a trio of cross-braces just behind those coils to stabilize them, which are similarly important. If you need pix, I can get some from the frames out back tomorrow.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Issue
« Reply #2 on: April 05, 2014, 10:04:26 PM »
That would be nice! I think this might be a good time to do a splice kit
Gus, Austin, MN.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: Issue
« Reply #3 on: April 06, 2014, 01:38:39 AM »
I would recommend Frank's (754) splice kit. Problem is, those tubes have been cut too far back to use it. You're going to need to extend those tubes to use any kit that I've seen. Shame.
Maybe a longshot, but do you think the PO might have the piece he removed? If you can resist wrapping it round his neck it might be easier to weld it back in and start again?
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Issue
« Reply #4 on: April 06, 2014, 04:35:24 AM »
No. he said he didnt even know. Ill find a welder who can extend those then instal the kit.
Gus, Austin, MN.
Re: Issue
« Reply #5 on: April 06, 2014, 04:45:06 AM »
I bought a bike once that had the same issue when I got it home. Luckily I bought it very cheap.
  Now I, and everybody else who is looking at a 750, should take a peek under the tank to make sure those frame sections are still intact.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Issue
« Reply #6 on: April 06, 2014, 05:00:35 AM »
By the time I croak I will know alot too on whay to look for. Its one of.those thinga I gotta decide whether or not im in for the long haul. I think this one will be for the long haul
Gus, Austin, MN.
Re: Issue
« Reply #7 on: April 06, 2014, 05:03:15 AM »
Nothing that can't be fixed.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Issue
« Reply #8 on: April 06, 2014, 05:10:58 AM »
Sweet. Hell, maybe it will be even better than before!
Gus, Austin, MN.
Offline Killer Canary
  • Typical Bran Muffin
Re: Issue
« Reply #9 on: April 06, 2014, 11:48:14 AM »
Someone saved you the trouble of cutting the frame yourself. Nifty! Now you can do a splice kit like the 750 should have had in the first place. Keep the weld heat down for the extensions and you'll be fine.
This is a case of making a silk purse from a sow's ear. 8)
Kawi GPz900, H1
Re: Issue
« Reply #10 on: April 06, 2014, 11:54:43 AM »
The key to extending those and ending up straight will be, using internal sleeves to help line it up. I can make those and maybe supply the tubing.
 If, you weld a whole new section in, then cut it in proper place, everything should stay straight.
 Is any of the upper brace left, as you will have to do some work there as well. Or make some new pieces.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Issue
« Reply #11 on: April 06, 2014, 12:08:58 PM »
PMd you. 1/2 inch back 1 inch front
Gus, Austin, MN.
Re: Issue
« Reply #12 on: April 06, 2014, 12:47:19 PM »
Yours is clearly cut too far back, but can be fixed up.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Issue
« Reply #13 on: April 06, 2014, 02:53:34 PM »
Cool
Gus, Austin, MN.
