Author Topic: CB400f Carb butterfly/choke valve/plate bent?  (Read 1866 times)
Offline Frogger
« on: April 05, 2014, 09:24:14 PM »
Apologies, not sure on the part name but the butterfly valve/choke flap seems bent on carb 3. Sure this is not right but how may it be remedied given the part is very hard to source (in Australia). What may be the result in running with this issue and how is it caused as an aside. Main query is how to fix the issue.
Many thank in advance.
Offline Bodi
Re: CB400f Carb butterfly/choke valve/plate bent?
« Reply #1 on: April 05, 2014, 09:31:15 PM »
You could remove it and flatten it but, as is, it shouldn't have any noticeable effect on performance or starting.
Offline Frogger
« Reply #2 on: April 05, 2014, 09:42:06 PM »
Thanks for the reply, given my ignorance, I have to ask, it gets a little stuck lifting it up I guess due to it not being perfectly round in shape with the bend - this has no bearing on how it will perform either? The either 3 mate with the carb body perfectly whereas this one leaves almost a mm gap.
Appreciate the response.
Offline harisuluv
« Reply #3 on: April 05, 2014, 10:05:28 PM »
well from your picture i can't see a bend.  looking at the face, i can't tell at all.  if you changed the position to choke is open, then I could probably see the bend.
Offline Frogger
« Reply #4 on: April 05, 2014, 10:22:08 PM »
Look between the screws, there is clearly a bend as opposed to the one on the right which is not.
Offline Trevor from Warragul
« Reply #5 on: April 05, 2014, 11:30:53 PM »
PM me your details & I'll send you one (I'm in Melbourne)
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
Offline Frogger
« Reply #6 on: April 06, 2014, 12:09:15 AM »
That is incredibly good of you, thanks very much, PM you now.
« Reply #7 on: April 06, 2014, 12:25:19 AM »
I'll pop it in the post tomorrow
Trevor
1971 Kawasaki H1A
1972 Honda CB350F
1978 Honda CBX
Offline Frogger
« Reply #8 on: April 06, 2014, 12:34:43 AM »
Thank you kindly Trevor, much obliged.
