Author Topic: 1975 CB750 K5 "Rhonda the Honda"  (Read 93081 times)
Re: 1975 CB750 K5 "Rhonda the Honda"
« Reply #100 on: May 08, 2015, 07:02:07 PM »
Hope you have the AAA RV/Motorcycle roadside coverage.  It's well worth it!
« Reply #101 on: May 08, 2015, 07:14:12 PM »
Is your system charging?
Online calj737
  • I refuse...
« Reply #102 on: May 09, 2015, 04:27:27 AM »
"Think you used enough truck there, Butch?"  ;)
« Reply #103 on: May 09, 2015, 07:34:25 AM »
I'm more surprised that they spanned the straps such a distance.  They usually use the tie-down points on the floor of the tow bed.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #104 on: May 09, 2015, 09:24:30 AM »
I was also surprised... but there were no issues.
My mother in law (also a rider) has it, and she's the one who bailed me out...
« Last Edit: May 09, 2015, 03:46:43 PM by evanphi »
--Evan
1975 CB750K "Rhonda"
Offline evanphi
  • Apparently I'm an
« Reply #105 on: May 09, 2015, 09:25:59 AM »
Yes it has been fine. I was just trying to squeeze the last life out of an old battery. I have an AGM on the way, but I am going to test the charging system this week to be sure.
--Evan
« Reply #106 on: May 09, 2015, 11:21:53 AM »
Oh, I know that experience!
Tasteful bleeps at 0:15, 1:26, 1:49 and 1:51 -- but you missed the last one at 2:14!  ;)
Offline evanphi
  • Apparently I'm an
« Reply #107 on: May 13, 2015, 07:52:45 AM »
New battery arrived today!
Glug glug glug
--Evan
Offline Maurice
« Reply #108 on: May 13, 2015, 09:54:37 AM »
That... is not AGM?
Also, keeping the revs high allows you to keep riding. Been there, of course all lights were turning orange as I was approaching... Still better to get a tow for the regulator/rectifier.
« Reply #109 on: May 13, 2015, 04:44:05 PM »
That... is not AGM?
+1  Why'd you buy an "acid spiller"?!
« Reply #110 on: May 13, 2015, 04:50:49 PM »
"For a few dollars more" you could have a battery that will not cook off the water with a Battery Tender.
Offline evanphi
  • Apparently I'm an
--Evan
Offline Restoration Fan
  • My wife will never call me
« Reply #112 on: May 14, 2015, 07:32:07 AM »
I think they weren't talking about an Absorbed-Glass Mat (AGM) battery.  They (and I ) thought you were saying you had ordered an Anti-Gravity Micro battery....sometimes called an AGM.
http://antigravitybatteries.com/
« Last Edit: May 19, 2015, 07:45:22 AM by Restoration Fan »
Offline Maurice
« Reply #113 on: May 14, 2015, 07:43:14 AM »
I was referring to Absorbed Glass Mat all right. It still is lead-acid, for sure, just no risk of spillage, and IME lasts a tad longer for some reason.
The battery evanphi is using actually is AGM, just one where you still add the acid and then seal. I never saw this, the AGM batteries I buy are already sealed and ready to use.
Offline evanphi
  • Apparently I'm an
« Reply #114 on: May 19, 2015, 05:23:05 AM »
Yeah I got mine mail-order!
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #115 on: June 06, 2015, 05:45:19 AM »
My bike wouldn't start yesterday.... OH NO A GREMLIN!!!
Took my tank off, started jiggling wires... IT CAME BACK ON. WOOHOO! Got me home...
Inspection (further jiggling of wires) this morning before big Ride for Dad event (you can still donate here) found that the switched power wire for my electronic speedo had come a bit loose! Fuxed her up good, and threw some electrical tape on there for good measure, too. All working fine now!
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #116 on: June 17, 2015, 06:07:04 AM »
New sprockets came by post! These are the sprocket part numbers for JT Sprockets if you're ever ordering stock gearing for a CB750.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #117 on: June 18, 2015, 08:28:25 AM »
Got a "bearing puller" from Canadian Tire...
5/8" sleeved concrete anchor! Going to open it up on the old bearing, and tap them out from the inside. Should save having to mess around with the internal spacer.
Also picking up my new Diamond chain from the post office today.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #118 on: June 25, 2015, 05:39:28 AM »
Ordered my tapered steering bearings and wheel bearings... All Balls for everything from http://www.canadasmotorcycle.com! Now I can get my wheels and swingarm all done up, I'm going to save the steering bearings for the winter.
The previous owner of my house left something like this:
in the garage... Couldn't figure what it was for until the other day. Bearing race remover! This will be helpful for the steering bearings job.
Ordered cush drive rubbers and a new o-ring for the rear wheel/sprocket carrier, new tongued washers for the rear sprocket, and new lockplate for the front sprocket. All from my local stealership.
Also ordered a new shield for my helmet, and some new gloves.
« Last Edit: June 25, 2015, 05:45:24 AM by evanphi »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #119 on: June 25, 2015, 06:30:26 AM »
Also going to be ordering new fork tubes and progressive springs. In a month or so...
The PO fork tubes are bent. When I removed the forks 2 winters ago to do the brakes, remove ears, etc... I noticed one fork tube wouldn't sit on the front wheel's axle bolt. I just spun the fork tube around until the fork lower slid sideways into place. In the meantime I may try turning them so the bends are both facing forward, at least, rather than to the side (which may be affecting my handling).
--Evan
« Reply #120 on: June 25, 2015, 07:08:06 AM »
If your fork tubes are bent (especially as much as you describe), do not use them as they will adversely affect the bike's handling.  The bike will never ride properly and may induce a wobble or worse.  The only thing they are really safe for now is holding up the front end until you get new tubes.
Offline evanphi
  • Apparently I'm an
« Reply #121 on: June 29, 2015, 07:27:06 AM »
Redid my swingarm bushings.
Removed the old ones...
Went to my in-laws and used the 10-ton shop press (mechanic for in-law is awesome!) to press them in...
Got everything back together with a nice coating of new grease. Going to ride it tonight.
Discovered something fun... Notice anything missing?
How about now?
Broke a forking spoke! No idea how long it has been like this. Anyone have a spare spoke for a 17" rim (Hondamatic/77-78K) they want to send me?
--Evan
Offline riffman12
« Reply #122 on: June 29, 2015, 10:29:57 AM »
yikes. that could have caused a bit of a mess. good thing you caught it
« Reply #123 on: June 29, 2015, 10:50:17 AM »
Other than a ticking sound, that lone broken spoke could have been there for some time without anyone noticing. That said, a new one will fix her up.
Offline evanphi
  • Apparently I'm an
« Reply #124 on: June 29, 2015, 11:34:10 AM »
That's what I figure. I know I did hit a pretty nasty pothole a few weeks ago. Rim not bent or anything, but might have popped this spoke.
OR it could could have always been there and I just didn't notice!
EDIT:
Hmmm... looking at this photo from a month or so ago, I think this broken spoke is new! Possibly that pothole I hit... All the spokes are intact in this pic.
--Evan
