Author Topic: 1975 CB750 K5 "Rhonda the Honda"  (Read 93317 times)
Offline calj737
  • I refuse...
Re: 1975 CB750 K5 "Rhonda the Honda"
« Reply #150 on: December 08, 2015, 07:53:02 PM »
Have you considered filling the crack?
Thats not a crack; its a chasm. It needs a jack hammer and re-pour. Anything short of that is not going to last, sadly.
« Reply #151 on: December 08, 2015, 07:59:29 PM »
Agreed, it looks like there's no mesh {reo} in that concrete so unfortunately it will probably keep moving...
« Reply #152 on: December 08, 2015, 08:05:54 PM »
That may be so but if he's not in a position to spend a couple thousand to repour, why not fill it so any small part doesn't get lost in the Grand Canyon?!
Offline przjohn
« Reply #153 on: December 09, 2015, 07:28:11 AM »
Also covered my boat for the winter.
That day always seems to come too soon every year.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #154 on: December 09, 2015, 07:57:36 AM »
--Evan
1975 CB750K "Rhonda"
Offline evanphi
  • Apparently I'm an
« Reply #155 on: December 25, 2015, 07:43:40 PM »
Bought some concrete fill! ;D
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #156 on: February 07, 2016, 03:46:58 AM »
WINTER 2016... The work begins!
I'm focusing on the front end this winter. New fork tubes, progressive springs, neck bearings, centering the front wheel, and a single front brake line.
PICS from yesterday.
Front wheel off! To get the axle nut off, I used a 15/16" deep impact socket on the nut and an 18mm open wrench on the other side. Came right off, no worries of rounding, and now I can torque it back to spec when it goes back together. Also removed... fender and brake.
Wheel mounted on the truing stand. I need to center the rim on the hub. I'll probably use a plumb line to achieve this to avoid removing the tire.
Headlight off...
Bars and controls off. Going to be buying a Renthal Ultra Low bar to replace this flimsy Emgo.
Forks out!
Races removed. I used an 8" long brass drift to get these out. Pretty easy!
These next two pictures demonstrate just why I'm doing this work. Bent (and rusty) fork tubes, and notched bearing races. The tip of the hex bit in the gap of the fork tubes is 8mm wide.
Click here to see the notchy steering in action! https://gfycat.com/SimilarCourteousArcticduck
Years of leaky brake fluid have killed the paint on the triples. I am going to polish the upper... no problemo. The lower, though, needs some work. Likely have it sandblasted and repainted.
Here's last night's work all laid out... Forks came apart no problem. I still hate the smell of old fork oil. I'll be re-purposing the straighter of the two fork tubes as my official "seal driver" using this method:
--Evan
« Reply #157 on: February 07, 2016, 07:03:07 AM »
Good winter project, I did similar on my K4 two years ago.
Suggest powdercoat for the lower triple, I rattle canned mine and bubbled a small area when a little brake fluid leaked on it.
Offline evanphi
  • Apparently I'm an
« Reply #158 on: February 07, 2016, 07:18:21 PM »
I'll be going to a single line, so that won't be a problem. Might just sand it back to good paint and rattle it.
ORRRR maybe polish and clear-coat?
--Evan
Offline calj737
  • I refuse...
« Reply #159 on: February 08, 2016, 03:36:36 AM »
Isn't the lower clamp steel? Hard to polish that one...
Offline evanphi
  • Apparently I'm an
« Reply #160 on: February 08, 2016, 08:16:26 AM »
sorry, i  meant strip raw and clear coat.
--Evan
Offline calj737
  • I refuse...
« Reply #161 on: February 08, 2016, 09:09:45 AM »
I was double-checking my info, not questioning you. Either way, as Stev-o said, its a great winter project
Offline evanphi
  • Apparently I'm an
« Reply #162 on: February 08, 2016, 11:13:53 AM »
Yeah I'm looking forward to it. A trip to the polishing/sanding wheel is in order then!
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #163 on: February 12, 2016, 06:13:40 AM »
Some more prep before re-painting the spots that brake fluid attacked on the trees...
removed the lower race, going to use the thin washer for the AllBalls kit. It is about .5mm shorter than the previous stack, but that will raise the fork/frame stoppers a bit. They were hitting right at the edges before!
New fork bits should arrive today from the stealership (piston rings, copper washers, hex bolts, and disk brake washers).
I leveled my truing stand, and it turns out my wheel is only a few mm off to one side, so I will be centering it less than I thought. The big offset I saw earlier was likely from the forks being so bent, and the fender is looking like it is skewed to one side, too. I'll straighten the fender legs.
This project is moving much faster than last year's! If not for paint, I could have it all back together by tonight!
Still to order:
Single brake line from Slingshot
Renthal Ulltra Low bar
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #164 on: February 14, 2016, 07:22:44 AM »
Progress...
Here's all my fork stuff laid out. Just waiting on a few more parts from the dealership.
ON the right you'll see the CB750 FORK SEAL DRIVER... OF SCIENCE!
PAINT!
Both fork holders needed paint after some run-ins with brake fluid.
Cleaned and prepped:
After two coats in the affected areas, then two coats over the whole piece to even out the slight difference in colour, all is hanging until I get to them on my next shop night, to install the bearings.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #165 on: February 15, 2016, 04:42:48 PM »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #166 on: February 19, 2016, 09:54:38 AM »
Plan for tonight...
Chase the M10x1.25 and M8x1.25 threaded holes in the triples to remove the paint
Remove any paint from flat bits of bar clamp and inside fork holders
Grease roller bearings
install roller bearing to steering stem with thin washer for spacer
install tapered cups to frame
install triples
install fork tubes and add oil and cap the forks off (I'll be devising some sort of clamp for this, I think... video may follow)
That'll probably be it for the night! Next I'll work on truing my wheels.
Ordered a new single brake hose from Slingshot (used code SOHC4 for 10% off!), and a Renthal LOW street bar so they will go on next week.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #167 on: February 22, 2016, 02:42:12 AM »
Turns out my PO was trying to kill me!
Got my new fork tubes from CycleX all nice and installed
Then I am installing the left side fender/caliper bolts (6mm), and they just keep turning and tuuuuurning... FACK.
Them's some nice stripped out holes. Might even have been some remains of blue loctite... BAH. The 8mm on bottom is fine, thankfully. That is what kept me alive these past three years of ownership!
Has anyone successfully Helicoiled these holes before? This is really my only option at this point... other than a plug weld and re-tap, but I don't want to alter the structural integrity of the fork lower by adding so much heat.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #168 on: February 23, 2016, 05:50:07 PM »
Now where were we...
Ah yes!
Cleaned out all those painted threads. No problem!
Upper and lower races both just pressed in most of the way. Couple taps with a bearing driver and they were both fully seated.
I used the THIN spacer under my bearings. The thick one was the buffer against the PVC tube I used to get the bearing to seat. A 2x4 under the lower triple-tree keeps it from getting scratched, as well as on top of the PVC to allow one or two sharp hits to drive it into place.
Installed everything on top! AllBalls includes a small washer to go UNDER the steering adjustment nut that fits in the grooves. It fits very nicely and now we have a rubber seal on top, too. Tighten that adjuster nut with the shock spanner until it just starts to get stiff (mine didn't LOCK, just got tight). Back off, then go again until tight, loosen 1/4 turn. Then put on the upper triple. Add the big washer, and finally the big nut. This needs to be very tight, as it locks the steering adjuster nut (I did the final tightening AFTER the fork tubes were installed).
MMM PURTY. Installing the progressive springs with spacer was a LITTLE difficult. Having the front end elevated helped. I just used a 15/16" deep socket to push down, and then turned 1/4 turn at a time to get it started. Once the threads caught you can tighten down. 225ml of 10W fork oil were added to each side first, as spec'd in the shop manual for dry forks.
What is dees?
Renthal Road LOW bar. Very lightweight. I'm going to have to open up the hole for the wires in the Right control switch housing because of no holes in the bar.
Continued...
« Last Edit: February 23, 2016, 06:17:43 PM by evanphi »
--Evan
« Reply #169 on: February 23, 2016, 05:57:22 PM »
Nice write up.  Did you consider polishing your lowers?
Offline evanphi
  • Apparently I'm an
« Reply #170 on: February 23, 2016, 06:02:01 PM »
I was going to put the front end all back together when I discovered that the upper two caliper/fender holes were stripped! Cold sweats and thoughts of mangled front breaks brakes ensued. Wife wasn't too happy when I told her about this:
"YOU COULD HAVE DIED!?"
"But I didn't!"
Anywho. The repair:
Stripped threads
I decided to Helicoil these. A couple users responded to my question (quoted a few posts above), saying helicoil would be fine.
Supplies:
1. M6 Helicoil kit (only one place in the city had individual size kits. Only 40$. Yes a whole kit is more economical, but I needed just this one size and wanted to keep cost as low as possible. Those new fork tubes are expensive!)
2. Tap handle (this kit was on sale from 49.99$ to 8.39$ LAST WEEK but one of the store clerks forgot to take the sale price off the shelf. LUCKY ME!)
3. Red thread locker, for extra security.
The kit:
Comes with a bunch of coils, the tap, and a neat tool for inserting. This is an actual HeliCoil brand kit, too. Part number is 5546-6.
Drilled with 1/4" bit.
Tapped:
The coil holder tool. It pre-threads the coil the same as the tap so it doesn't get all wobbly when going in.
Inserted with red thread locker, 1 turn below surface!
Cleaned up:
Then you just punch out the extended piece that helps turn it into the hole. I used a 3/8" punch.
Done!
Front end will be put back together tomorrow, and I'll also be working on truing my front wheel. I found a neat trick to see how far off to one side the wheel is... stay tuned!
« Last Edit: February 23, 2016, 06:07:02 PM by evanphi »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #171 on: February 23, 2016, 06:11:26 PM »
Never did. I'm not really one for lots of shine. In fact, someone is sending me a set of side covers and a second tank so Rhonda can have a more "ugly bike" look. I plan to strip the tank and clear-coat it and just rattle-can black the side covers.
Then I can change the sidecovers and tank out as I see fit, depending on the mood I'm in that summer/week/month/ride.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #172 on: February 24, 2016, 11:09:27 AM »
Front end mostly back together...
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #173 on: February 24, 2016, 11:14:58 AM »
Here's that trick to see how much offset your wheel has without removing the tire/tube/rim-strip. It'll be about 5mm, this was standard from factory... but this will also help you get it well centered.
I'm silly. Don't use string hanging over a tire. That'll just be inaccurate. Use a straight edge on the hub about a foot long, and then measure to the lip on the rim. The rest is the same:
Measure the closer side
Zero your caliper
Measure the further side
And there's your offset!
Now you can center your wheel. The distance should be the same on both sides.
If you have a dial gauge, you would set it on one side, then adjust the wheel over towards center HALF the value you got for offset. If you don't have a dial gauge, you'll have to re-measure using the above method.
« Last Edit: February 24, 2016, 04:19:54 PM by evanphi »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #174 on: February 25, 2016, 06:04:17 PM »
Protip:
If your grips are not sticking to your bar, you probably have some of this around the house...
I don't know why, but these grips held fine on my previous chromed bars. They wouldn't stick on the powdercoated Renthal, though, even with the knurled grip area.
« Last Edit: February 26, 2016, 02:57:49 AM by evanphi »
--Evan
