Author Topic: 1975 CB750 K5 "Rhonda the Honda"  (Read 94547 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: 1975 CB750 K5 "Rhonda the Honda"
« Reply #175 on: March 14, 2016, 08:12:23 AM »
Everything is all buttoned up... had to replace the headlight fuse, but everything works and the AGM battery was still above 12V, being stored indoors all winter. Great battery!
BUT THEN...
FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUCK.
It's all still holding, but this one holder for the new headlight ears CRACKED. I've contacted the seller for replacements...  >:(
Just need some fresh gas, and I'll do a clear tube check before riding.
--Evan
1975 CB750K "Rhonda"
« Reply #176 on: March 14, 2016, 08:16:36 AM »
That was a good catch.  I had a headlight bucket break (with a HEFTY die-cast Truck-lite housing) while I was riding once.  It was no fun having to cradle my headlight for 40 miles.
Offline evanphi
  • Apparently I'm an
« Reply #177 on: March 21, 2016, 05:38:38 PM »
Looks like the sidecovers I got from edwardmorris were originally orange flake. neat!
Going to work on getting as much paint as possible off these, and then picking out what colour do to them with. Not going to be too fussy with leftovers, though... going to be rattle-canned.
« Last Edit: March 21, 2016, 05:40:55 PM by evanphi »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #178 on: March 31, 2016, 09:23:52 AM »
Is it safe to use a wire cup brush or wheel brush in a mini-grinder on these tanks to remove all the old paint (and prev PO horrible paint job)?
Or should I use chemical strippers?
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #179 on: April 02, 2016, 09:12:19 AM »
Rhonda rides again!
Went for a quick shakedown ride today after setting float heights. Glad to be back on the road with her.
The bottom of the meniscus sits right at 3mm for all the carbs. I measured them all off the same carb so they're as equal as they're ever gonna get! They all had to come up about 2mm.
Pro tip: If you want to raise the float height without removing the float (and losing your needle) each time, you can reach in there and give the tang a pinch (to lower it) with some long-nose needle pliers. If you need to lower your fuel level, raise the tang up with a flat screwdriver. The hose for mine is made with an old drain plug that I cut the head off, and jammed onto a piece of 1/8" fuel line.
« Last Edit: April 02, 2016, 09:14:03 AM by evanphi »
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #180 on: April 17, 2016, 09:56:16 AM »
Rhonda's Glam shot, 2016.
--Evan
« Reply #181 on: April 17, 2016, 10:31:57 AM »
Very nice.  It still looks a wee bit chilly from the look of the hibernating grass and trees.
Offline evanphi
  • Apparently I'm an
« Reply #182 on: April 17, 2016, 10:59:43 AM »
+8 Celsius in the direct sun. Cool, but you'd still get a sunburn.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #183 on: April 17, 2016, 11:05:00 AM »
This wash made me realize that VHT Header paint really sucks.
Going to wrap those crappy MAC headers soon, then look into getting a stainless set made/purchased. Maybe Hindle.
Also need to touch up the black engine paint.
--Evan
« Reply #184 on: April 17, 2016, 11:46:33 AM »
It most likely comes down to prep. Did you sandblast before paint?
Offline evanphi
  • Apparently I'm an
« Reply #185 on: April 17, 2016, 02:01:09 PM »
I didn't sand blast but I had removed everything with chem stripper. Also notice the grey primer is holding fine...
--Evan
« Reply #186 on: April 17, 2016, 06:06:08 PM »
I haven't heard the Hindle on a 750 but it sounds great on the 550 and 650.
Offline evanphi
  • Apparently I'm an
« Reply #187 on: April 20, 2016, 05:14:29 PM »
Gave Rhonda's jugs (hehe) a clean, and spot-sprayed some flat black engine enamel. Next will be touchups on the pipes.
--Evan
« Reply #188 on: April 20, 2016, 10:26:57 PM »
So, you spruced up her jugs, and didn't even have to see a plastic surgeon in Newport Beach.
Offline evanphi
  • Apparently I'm an
« Reply #189 on: April 26, 2016, 09:32:41 AM »
I set up my progressive springs with the recommended amount of fork oil from the factory manual (rebuilding from dry), as well as the 1" PVC spacers. My forks are now topping out (hearing a ka-thunk after going over a longer bump with some speed). Is it just too much preload for my weight (170lbs)? I just find the ride is overall more harsh than before.
Should I just try running without the spacers to reduce preload?
--Evan
Offline edwardmorris
  • Youngish
« Reply #190 on: April 26, 2016, 09:38:43 AM »
What weight oil? I'm 175lb (after a good buffet lunch :P), using factory spec amount (rebuilding from dry) and no spacers with 10w30 diesel engine oil, the front is damn near perfect.
Offline evanphi
  • Apparently I'm an
« Reply #191 on: April 26, 2016, 10:40:06 AM »
10W fork oil, 225mL per leg.
Are you running progressive springs, Rafi?
--Evan
  • Youngish
« Reply #192 on: April 26, 2016, 12:10:37 PM »
Yep, on both of mine.
« Reply #193 on: April 26, 2016, 02:44:05 PM »
I did not use the spacers on my K4 and all is good.  And used ATF.
Offline evanphi
  • Apparently I'm an
« Reply #194 on: April 26, 2016, 02:44:10 PM »
I think I'll take my spacers out, then. See if that makes a difference. They just feel super stiff now, front end feels harsh. That to me says too much preload.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #195 on: April 26, 2016, 05:42:38 PM »
Took the spacers out... now I can actually compress the forks with my body weight. I think it was just too much preload.
--Evan
  • Youngish
« Reply #196 on: April 26, 2016, 08:03:42 PM »
You work fast ;D I've been bumming around lately due to longer work hours, I need get my forks back together soon.
Offline evanphi
  • Apparently I'm an
« Reply #197 on: April 27, 2016, 05:11:27 AM »
Wife out for the night and sleepy kid in bed before 7PM. ;D
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #198 on: April 27, 2016, 04:31:56 PM »
BBQ paint for the pipes...
--Evan
Offline 700504
« Reply #199 on: April 27, 2016, 04:49:06 PM »
Looks awesome!
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
