Author Topic: 1975 CB750 K5 "Rhonda the Honda"  (Read 94830 times)
Re: 1975 CB750 K5 "Rhonda the Honda"
« Reply #350 on: August 18, 2018, 04:57:44 PM »
She looks no worse for wear after your work to get her back on the road.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #351 on: August 20, 2018, 07:39:20 AM »
Thanks. She's a joy to ride, as always.
--Evan
1975 CB750K "Rhonda"
Offline evanphi
  • Apparently I'm an
« Reply #352 on: August 07, 2019, 10:28:17 AM »
So it has been almost a year of problem free riding... just the regular stuff...
Got back from a nice long trip during which I noticed lots of fork oil leakage. YES I USED AFTERMARKET FORK SEALS. So yesterday I called my local and ordered two new Honda fork seals. They'll be going in ASAP. :) I'll be using the same methods I did the last time.
--Evan
« Reply #353 on: August 07, 2019, 11:46:27 AM »
Evan, glad it has been a good year of riding! David
Offline evanphi
  • Apparently I'm an
« Reply #354 on: August 07, 2019, 12:02:24 PM »
Thanks David!
I hate to possibly take time away from riding/family time... but work has to be done!
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #355 on: August 12, 2019, 06:24:13 AM »
Changed my fork seals on Saturday. Very easy to do without a complete disassembly.
Jack up the front end
Remove front wheel
Remove speedo cable
Remove brake line
Release fork bolts from bottom of fork lower with Hex wrench (HERE COMES THE OIL! Have your catch pan ready!)
Gently pump fork lowers + fender up and down a few times to clear out the oil
Remove fork lowers (Uppers will continue to drip as you do the seal replacement!)
Remove old fork seals
Reinstall new fork seals
Reinstall fork lowers
Reinstall fork bolts after replacing or annealing copper crush washers (torque to 15#)
Replace wheel (torque pinch bolts to 15#, front first, gap to rear)
Replace speedo cable
Replace brake line (good time to rebleed brakes to remove air)
Loosen top triple's pinch bolts
Remove fork caps ONE SIDE ONLY (carefully!) You may have to remove your bars for this step
Fill with 150ml of ATF or fork oil of your choice
Replace cap to snug and proceed to other side
Re-torque top triple pinch bolts
Replace bars if required
Double check torque for all fasteners
Bounce forks up and down a bunch to get the oil flowing and to check for leaks. Now is a good time to see that your copper washers didn't seal and you're leaking fork oil rather than 10K down the road!
Done!
Changes noted: ATF will be my go-to fork oil from now on. Much faster on the quick small bumps we have around here (lots of road repairs/patches and potholes). Previously used 10W fork oil.
I changed the nuts on the axle pinch bolts to Nylocks + reg washer rather than the spring washers. When I was loosening them they were alarmingly loose. Those split spring washers were quite tired and NOT doing their job.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #356 on: August 16, 2019, 09:46:22 AM »
I've got a screw loose!
Time to disconnect the tach cable until winter arrives and I can take that guy apart.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #357 on: June 16, 2020, 10:27:58 AM »
Well the tach is bach (heh) on and riding is back in full swing!
Needed a new rear tire so I ordered myself a BT-46, which is the new replacement for the BT-45 we all know and love.
When removing the old tire I accidentally ripped out the valve stem from the tube... I guess it rotted over the past couple years. On closer inspection I think I used WAY too much soapy water when mounting last time as there was still a ton of soap bubbles under the tire. I'll use little to none this time. So I had to drive my car to work today... :( But picking up a new tube on the way home will fix all this!
Tonight will be a true, mount, and balance.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #358 on: June 19, 2020, 11:58:51 AM »
Got that BT-46 mounted on Tuesday and had my first ride on it last night. I love the feeling of a fresh tire! Turning is so much easier than a something squared off.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #359 on: July 03, 2020, 04:55:56 AM »
Installed an LED headlight bulb. It is this one on amazon: https://www.amazon.com/DZG-Motorcycle-Headlight-Conversion-Warranty-1/dp/B07BTTFN1S/
So far so good. I can actually see a bright spot on the road now, even in daylight.
--Evan
Offline Desert-SOHC
  • It's old
« Reply #360 on: July 03, 2020, 12:27:17 PM »
How focused is it at night?
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline evanphi
  • Apparently I'm an
« Reply #361 on: July 10, 2020, 09:59:26 AM »
Don't know yet. Haven't had a night ride since. It is a Hella reflector, so good quality. I don't often ride at night due to my own vision issues, but I can certainly see a brighter beam pattern compared to the stock H4.
--Evan
