Author Topic: Things to check when a newly assembled engine won't run  (Read 4309 times)
Offline Nick0
Re: Things to check when a newly assembled engine won't run
« Reply #25 on: April 07, 2014, 12:01:59 PM »
Okay I should be able to post compression readings within a couple hours
Offline Nick0
« Reply #26 on: April 07, 2014, 01:29:21 PM »
Just started testing compression, cylinder 1- 0psi
Offline Nick0
« Reply #27 on: April 07, 2014, 01:32:26 PM »
Offline Nick0
« Reply #28 on: April 07, 2014, 01:32:47 PM »
Cylinder 2, yep you guessed it, 0 psi
Offline Nick0
« Reply #29 on: April 07, 2014, 01:33:45 PM »
So what do I need to do to correct this
Offline Nick0
« Reply #30 on: April 07, 2014, 01:37:17 PM »
And yes my compression checker is working
Offline iron_worker
« Reply #31 on: April 07, 2014, 01:55:45 PM »
I adjusted my tappets according to the Manual. Rotated the engine clockwise untill both valves on the right hand cylinder were closed and timing mark pointed to the t(indicating a compression stroke) then set the indicated tappets then did one more rotation and stopped at t and set all other tappets
Well not sure if you just described it wrong or if you did it this way but that's not the way to adjust tappets.
Set the motor to TDC #1/4. Check cylinder #1 and #4 ... one of those two should be on the compression stroke (both valves closed ... or should have some play in the rockers ... but might not if you set it way out of wack).
Adjust the tappets for the cylinder that is on compression.
Rotate the motor 360 degrees and do the #4 if you did #1 before or vice versa. Adjust those tappets now.
Put motor to TDC #2/3. Find which cylinder is on compression stroke as before and adjust those tappets.
Rotate motor 360 again and bring back to TDC 2/3. Adjust 3 if you did 2 before or vice versa.
Done.
IW
Offline Nick0
« Reply #32 on: April 07, 2014, 03:48:26 PM »
My cam was 90 degrees off I accidently alined the sprocket marks vertically instead of horizontally. I just Fixed it and it started right up. Thanks to everyone who contributed you guys really helped me out
Offline thep1pe
  • Proud Owner 76 CB550F1
« Reply #33 on: April 07, 2014, 03:54:33 PM »
Don't even think about 180 degree out cam FFS. You will start a small war!!!!
Sent from my iPad using Tapatalk
AJK
« Reply #34 on: April 07, 2014, 04:01:44 PM »
Glad you got it all running fine. The whole thing smelt like it was valve timing from the onset. Congrats & enjoy the bike.
Offline mcswny
« Reply #35 on: April 07, 2014, 04:59:21 PM »
Good job!
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline trueblue
« Reply #36 on: April 08, 2014, 03:07:41 AM »
Cams can't be 180 out but they can be 90 out, anyone with half a clue as to the basic opperations of a piston engine would know this. ;)
To the OP, you are very lucky to have not smacked your valves with the pistons with your cam bing that far out.
1979 CB650Z
