Author Topic: head torqing question  (Read 426 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: April 09, 2014, 07:56:02 PM »
when using HD studs, what torque values do you use for the 4 screws under the pucks & the 2 for/aft of the cam tunnel?
I would guess it has to be stock specs so the threads don't pull out but then when I over analyze it (as usual) it seems that if the 6 non-HD fasteners aren't torqued the same as the studs then the head will be subject to uneven clamp force & could warp. ??
Re: head torqing question
« Reply #1 on: April 09, 2014, 08:50:54 PM »
90inch lbs
Offline grumpy
« Reply #2 on: April 10, 2014, 07:52:45 AM »
right-o
thanks
