Author Topic: setting timing with electric light  (Read 376 times)
Offline hymodyne
« on: April 10, 2014, 06:04:49 AM »
I haven't posted here for years...a testament to the advice I have received from the forum members.
I have checked the FAQ for Ignition and Lloyd's posts on the subject; I can't find my honda  service manual CD.
I am trying to set the static timing on my 550K, using the light bulb method. new points and condensers, points gap set to 15 thou.  If someone would post the instructions for this I would appreciate it
James
Offline LesterPiglet
  • 1977 CB550F2
Re: setting timing with electric light
« Reply #1 on: April 10, 2014, 07:06:35 AM »
Disconnect condensors. Connect lamp lead to points power for 1/4 and the other to ground.
Ignition on. Turn the engine with the large 23mm nut. Light should come on when the 1/4 F mark is lined up.
If it doesn't rotate the large timing plate until it does.
Same again for 2/3 except use the smaller timing plate to align the F mark.
Offline hymodyne
« Reply #2 on: April 10, 2014, 07:33:44 AM »
Many thanks.
