Author Topic: Help me identify this Brembo caliper..  (Read 2649 times)
Offline Justind97
« on: April 10, 2014, 04:04:42 pm »
Hey guys,
I bought this caliper set off the bay. They were advertised as a set of F08 calipers, only now that I look at them finally (A few months later) they are not true F08s.  They look very similar when assembled, however all the F08s that I see have a 2 pin design to hold the pads.  Mine is a single pin.
The part numbers that I found on them are 20.2420.00 and 20.2419.00   A google search left me empty handed.
Any help??
Offline Justind97
Re: Help me identify this Brembo caliper..
« Reply #1 on: April 10, 2014, 05:01:29 pm »
Figured out they were F05 calipers by measuring the piston which was 32mm.
Offline turboguzzi
« Reply #2 on: April 11, 2014, 12:40:58 am »
definetely 05s, 08s are much bigger overall indeed :)
hope you didnt pay for them 08s prices which are usually much higher than 05s at least here in italy....
not bad calipers, I have a set on my 500/4 racer, but they will be undersized on a 750
Offline Justind97
« Reply #3 on: April 11, 2014, 02:57:55 am »
I think I paid $100 shipped.
They we're to go on a 550.   Now they'll just go back on ebay.
« Reply #4 on: April 11, 2014, 03:44:23 am »
Justin, like TG I use those too. If you're using two disc rotors these are all the caliper you need. If you plan on a single rotor maybe a larger caliper is better?? Pads & replacement parts are readily available. They're certainly lightweight.
How's the bike coming along?
Offline Justind97
« Reply #5 on: April 11, 2014, 09:44:58 am »
Brent.   I ordered a set of True F08s this morning.    I had already ordered the rebuild kit for the F08s, so why not?!
You run the F05s or the 8s?
Difference being about 4mm difference per piston between the two.
I want to run a single caliper.   Will the 8s be enough?   Sure hope so.   Also looking for a new master.   Recommendations?   Or just rebuild the stock 550 one?
Bike is at a bit of a standstill.   Waiting on crank bearings.   Everything else is pretty much ready to go after that aside from paint and mounting the fairings.
« Reply #6 on: April 11, 2014, 10:12:23 am »
I think the single F08 should do the trick, but I have no experience with that set-up. Check out Vintage Brake for matching the right master. I use a 12mm Brembo master cylinder and the feedback is excellent.
« Reply #7 on: April 11, 2014, 10:29:31 pm »
The stock 550 14mm MC should work well with one twin 36mm piston caliper.
Offline turboguzzi
« Reply #8 on: April 12, 2014, 01:37:59 am »
if you are planning to race on single disc then fit at least a 300mm rotor.... preferably cast iron.   make sure you get racing compound pads for them too, look them up in the ferodo racing site.
« Reply #9 on: April 12, 2014, 05:37:50 am »
You know what TG, I found it hard to trail brake with those CP211 racing pads. There is so much "bite" with those that it seemed harder to modulate the front. I actually prefer the street version 207's for that reason, plus I've been focusing on not having to stand it on it's nose anyway (or had been focusing!)
With a single rotor though it might be wise to have a set of race pads to try. Another source of Ferodo pads is Mr. Morse at Vintage Brake. He's a great resource of information too Justin.
