Author Topic: Where to pull engine oil temperature? Oil pan or oil tank?  (Read 1817 times)
Offline wiskey
« on: April 11, 2014, 06:54:12 AM »
 I am in the process of wiring up a Motogadget gauge and will be installing an oil temp sensor.
The sensor will be the type where you replace the oil drain plug with this sensor.
I can either put it in the oil tank or the oil pan under the bike.
Where would you install it?
Thanks!
Offline Old Scrambler
Re: Where to pull engine oil temperature? Oil pan or oil tank?
« Reply #1 on: April 11, 2014, 07:08:13 AM »
Take your choice..............the oil gets heated the most by passing through the head of the motor. Keeping an eye on oil temp won't hurt..........but keeping the proper amount of oil in the system is a must ;) ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: April 11, 2014, 07:24:33 AM »
Oil tank - mainly because of the wires.
Offline mec
« Reply #3 on: April 11, 2014, 08:44:05 AM »
important to know the oil temp in the engine.
useless to know it in the oil tank.
mec
Honda Monkey
Takeuchi TB 070
Massey Ferguson
Offline Dream750
« Reply #4 on: April 12, 2014, 05:52:16 AM »
I would install it at the main oil gallery plug as that’s a good spot to monitor the oil temp going up to the cylinders/head. I use a oil tank dipstick thermometer knowing that it’s not the best location, but still reads relative for my needs.
Besides, I’m not ready to give up my (obsolete aftermarket) screw-in Isocycle main oil galley cooler that was seen back in the heyday.
Offline Tintop
« Reply #6 on: April 12, 2014, 10:48:56 AM »
If your converting to a spin-on filter, tap into the adapter plate and mount your sending unit there.  That will give you a temp reading of the oil just before it enters the engine main bearings.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline johno
« Reply #7 on: April 12, 2014, 04:06:21 PM »
It wont matter where you put it wiskey.
In terms of looking at a gauge using that information to make a decision,  any time difference wont make any difference. Re temp variation its up and down all over the place but only couple of degrees.
SO put it in the most practical easiest spot, have a slug of whisky, chill out and enjoy the fruits of your labour knowing if its a stinking hot day the oil will be hot , if its a cold morning and you want to flog the guts out of the motor you just gotta wait a while. ::)
johno
GRASSHOPPER SOHC HONDAS ARE THE MEANING OF LIFE.
Offline Whaleman
« Reply #8 on: May 04, 2014, 08:39:03 AM »
I put mine in the sump. I tapped the plug on the left side. This way if I messed up I could buy a new plug. It is also more protected here. Dan
