Author Topic: Staked Bearings Confirmation  (Read 460 times)
Offline capnvini
« on: April 12, 2014, 08:12:48 am »
Just wanting to confirm: 1- that you drill down into staking as deep as it goes.
                                    2- that you turn the bearing retainer clockwise to remove
                                    3- that you clean up threads or re chase
                                    4- when putting in new retainer to use loctite instead of staking
                                    5- anything special to be careful of?
                                    6- on the hub side where the rubber dampers are, does this retainer turn clockwise to come out as well? I have not seen much reference to this side.
Thanks, for the info
« Last Edit: April 12, 2014, 08:15:05 am by capnvini »
1975 CB750K, 1974 CB750K, 1973 CB750K, 1976 CB400 SS, 1981 Honda Passport, 2009 BMW K 1300S, 2012 Honda CBF1000
Offline capnvini
Re: Staked Bearings Confirmation
« Reply #1 on: April 12, 2014, 10:17:15 am »
Found a bunch of other threads I didn't see before. Think I have it now. But appreciate feed back.
thanks, Vince
« Reply #2 on: April 12, 2014, 11:22:34 am »
As deep as it goes-yes
Counter clockwise-yes to all if CB750. IF cb500, one is a reverse thread.
Clean up threads is good, but not necessary usually.
I wouldn't use loktite, rather restake. You may want to remove it again sometime, or the next guy.
Offline capnvini
« Reply #3 on: April 14, 2014, 03:34:37 pm »
Had success getting retainers out. One post said  to turn clockwise out but that is definitely wrong. Definitely counter clockwise to remove. Drilling into stake far enough important. I used the "U-bolt" type made up tool for the retainer in the final drive flange and it worked well. The grinder wrench slipped out and hacked up the retainer, it also bent the pins. Hope this adds a bit story.
