Author Topic: Throttle Question cb750f  (Read 594 times)
Offline RainsongCB750F
« on: April 12, 2014, 04:29:01 pm »
Hey everybody,
I know its common to have a throttle thats hard to twist on a cb750f because of the beefy spring but my throttle is only hard to twist right at the beginning of acceleration. its hard to explain but when twisting the throttle wide open its easy but right when first twisting its hard to open. if that makes sense? This is causing it to be hard to take off in first gear without a stumble. know what I mean?
1978 CB750F
When Jesus comes back he will ride an SOHC4.
Offline goldarrow
  • one day, i'll be an
Re: Throttle Question cb750f
« Reply #1 on: April 12, 2014, 04:34:51 pm »
Try lube the throttle cable or change new one
CB550 K0
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: April 12, 2014, 05:34:13 pm »
And make sure nothing is interfering with the cable pulley...if it has one.
« Reply #3 on: April 14, 2014, 01:16:48 pm »
I have replaced the cable twice and lubed it. Adding the lube helped it a little but it is still stiff in the beginning of the twist.
1978 CB750F
  • 1977 CB550F2
« Reply #4 on: April 14, 2014, 01:32:34 pm »
A routing problem?
Offline goldarrow
« Reply #5 on: April 14, 2014, 05:36:38 pm »
Post couple pics how you have your cables routed?
CB550 K0
« Reply #6 on: April 14, 2014, 06:58:41 pm »
Adjusted too tight?
« Reply #7 on: April 15, 2014, 07:22:03 am »
A routing problem?
+1
What year? I can check my 75/76 schematic and describe the routing but not until this weekend.
