Author Topic: Wiring Car start/starter solenoid and Reg/Rec question on '75 CB750sohc  (Read 403 times)
Offline danieldeanwilson
Hey guys. Just signed up for the forum, and I have a wiring question for a key ignition/starter switch
1.[/b] The key is off/on/start with no ground
There are three terminals which I have wired:
Batt-goes to battery for power.
Ign-goes to all of my switch positive 12 wires to complete the circuit.
start-goes to red/yellow wire on my starter solenoid.
I also have a green/red wire coming off of my starter solenoid next to the red/yellow. The OEM Diagram shows that the wire goes to switch positive 12, but then there is no ground, and my start switch has no grounding wire. Should this wire go to a ground, or to a switch positive 12?
I have the two terminals on the bottom. one goes to battery, and the other to the starter. I believe this is right. if not, please correct me.
2. I have a dyna ignition that was already installed on my bike. It has:
1-black wire
1-white wire
2-red wires
I think the black and white wires go to my yellow and blue wires and the red wires go to switch positive 12 to power the dyna. Is this correct?
« Last Edit: April 16, 2014, 04:02:10 PM by danieldeanwilson »
