Author Topic: Stuck clutch plates after winter  (Read 699 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« on: April 17, 2014, 09:02:11 AM »
Getting Rhonda back up and running for spring... clutch plates seem to be stuck like a peanutbutter and honey sandwich.
Should I just start it in neutral on the centre stand and let the oil warm up and circulate and then pop it to first and gradually let the clutch out?
I think all the oil is pretty coagulated down there... it was having trouble switching gears, too. Maybe some Seafoam in the cylinders to drip down overnight?
--Evan
1975 CB750K "Rhonda"
Re: Stuck clutch plates after winter
« Reply #1 on: April 17, 2014, 10:15:12 AM »
That's quite common. Start up the bike,maybe tie the clutch handle back with a rope for awhile. Let the engine and oil warm up . If it still has not broke free after a bit, with the engine off, put it in third gear, let out the clutch and rock it back and forth a little to break it free. Don't tear it all apart yet.
Offline evanphi
  • Apparently I'm an
« Reply #2 on: April 17, 2014, 11:08:57 AM »
That's what I figured, just wanted to see if anyone else had similar experiences. :)
--Evan
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #3 on: April 17, 2014, 04:55:06 PM »
I've had that problem forever with my 550. I find the easiest way to free it up is to have the bike in neutral, pull the clutch lever in & operate the kick starter until the clutch breaks free. Leave the fuel & ignition OFF until she frees up.
I've found an improvement since changing to another oil, but I'm not silly enough to start another 'Oil Thread'.  ;)
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
