Author Topic: CB750K1 Carburetor Specifications  (Read 421 times)
Offline Dale
« on: April 17, 2014, 10:42:01 AM »
I live in South Africa and am restoring a CB750K1. The bike was a none runner when purchased and came with a set of #064 carbs. These carbs were beyond repair so I found a set of 7A carbs. The 064 carbs have a slide needle with the number 271307 stamped in it. The slide needles from the #7A carbs have the number 27201 stamped in them, What is the correct needle to use in the 7A carbs for my K1 model.
Dale Maxwell
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
Re: CB750K1 Carburetor Specifications
« Reply #1 on: April 18, 2014, 05:00:06 AM »
I have the 7a carbs first of all good luck with them and I will get back to you with the #
Offline lucky
« Reply #2 on: April 18, 2014, 08:07:43 AM »
Forget the numbers on the needles.
Honda used different numbers on parts even though that same part was used on different models.
Just get the right slide needles based on the year of the motorcycle.
