Author Topic: '73 500 Cam Chain/Tensioner recommendations  (Read 397 times)
Offline calj737
  • I refuse...
« on: April 17, 2014, 04:23:33 PM »
So I'm having my motor completely rebuilt due to neglect from a PO. I'm also having it hopped up a bit with a Stage 3 Mike Rieck head job, new Megacycle cam, CR-26 carbs, and 59MM pistons.
My question is: other than a "stock" replacement, is there a recommended aftermarket cam chain and tensioner, and a different than stock primary chain? I have no qualms about using the stock replacements parts, but was curious if I should use a different brand and model.
