Author Topic: Petcock upgrade for 73 750 gas tank  (Read 1350 times)
« on: April 18, 2014, 06:06:32 AM »
The title says it all, since I am piecing the bike together - to make it reliable and easy to maintain - I would not mind changing the old style petcock to some newer version.
Anybody done it?  I would make an adapter to bolt on the tank with a bunk and the new petcock would screw on the adapter.
Offline bjbuchanan
Re: Petcock upgrade for 73 750 gas tank
« Reply #1 on: April 18, 2014, 11:14:26 AM »
Only thing is how low it could hang. A good setup would have it up high, if it gets a bit lower from the adapter it would hit the carb rack
« Reply #2 on: April 18, 2014, 11:18:24 AM »
Yep, I walked to the parking lot to check it out and that seems to be the most limiting factor.
Offline Old Scrambler
« Reply #3 on: April 18, 2014, 01:14:45 PM »
2 fuel-lines are required and at the measured flow from the stock petcock. If you change the rate of flow........your asking for trouble. The stock unit is basically the same as used on the CL72 beginning in 1962.  It worked well for new production bikes to 1976.  Miy K3 unit still works like it should and has yet to be rebuilt. Units and parts are readily available.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #4 on: April 18, 2014, 01:41:48 PM »
One word...
 PINGEL
« Reply #5 on: April 18, 2014, 01:53:55 PM »
I don't think the 2 line v the 1 line makes any difference Dennis. The original 2 line cock was replaced with a 1 line cock on essentially the same bike, CB750K. Around K4 I think.
« Reply #6 on: April 18, 2014, 02:44:00 PM »
I like PINGEL............made in Wisconsin..............and they flow very well.  MC.......Your almost right (better than my off-handed statement "to 1976"). K5 they moved to the left side and single line.........but I think larger diameter...............
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=ub2en6l6vstcllhdo15d9ofe80&/topic,60973.0.html
« Reply #7 on: April 18, 2014, 02:49:50 PM »
my cbx 1000 1978... 105 hk use a small 1 line petcock...so think not it give problems .....
i hate all this v-w.... vords
« Reply #8 on: April 19, 2014, 06:03:40 AM »
Nope, same size. Always 5.5mm.
Offline Airborne 82nd
« Reply #9 on: April 19, 2014, 07:01:50 AM »
Not mine stock 78 750K valve ID is 3.45mm measured 3 times most likely should be 3.5mm. Now the fuel line is 5.5mm ID has to be to go over the valve extra tight.
« Last Edit: April 20, 2014, 06:26:47 PM by Airborne 82nd »
Offline Whaleman
« Reply #10 on: April 19, 2014, 09:00:45 AM »
Check out my internal filter in the tips and tricks section under Carbs. Dan
Offline kball
« Reply #11 on: April 19, 2014, 08:47:23 PM »
Whats wrong with the stock petcock?
Offline neilc
  • old school biker,other bike is a 2003 vtx1800c
« Reply #12 on: April 20, 2014, 03:34:20 PM »
Pic for Dan
« Reply #13 on: April 20, 2014, 04:14:43 PM »
I think a brass ball valve would cleaner.... How much reserve is that. 6 tablespoons?
Offline vames
« Reply #14 on: April 21, 2014, 06:47:21 AM »
Pingel makes adapters. You just have to drill holes to match the screw spacing on your tank. (Or you could pretty easily copy this design).
http://www.dimecitycycles.com/vintage-caferacer-cafe-racer-bobber-brat-chopper-custom-motorcycle-carburetor-fuel-tank-parts-pingel-universal-petcock-adapter-nut-49-7738.html
« Reply #15 on: April 21, 2014, 07:13:31 AM »
Thanks guys, very helpful.
The tank I have is somewhat bent around the petcock mounting holes and i am afraid the stock petcock will not seal against it.
