Author Topic: Another CB750 build here in central PA - 1974 CB750  (Read 4555 times)
Offline BLEAMA
« on: April 18, 2014, 06:39:57 AM »
Hi I 'm Jim...  I have been looking at these pages for sometime as a guest and decided to join and post my project.
Started this journey at the end of last summer...want to be done in May.
Here is the bike as pictured in the EXXy auction:
Here is the listing description:
The frame with title is worth  $250 !
1974 Honda CB750 K4  Semi Survivor - Not Running -  Needs work
17,400 original miles !
Clean PA TITLE !  -Pa is a notary state so title will need to be notarized !
Picked this up from a friend of a friend. He had stored it in his basement since 2009 at that time it was running. Unfortunately he removed the plugs and moisture got into it and the motor is now frozen [I have penetrating fluid in cylinders but its still not turning over. Top end will probably need to be town down.
Gearbox shifts fine, clutch works [releases].
Speedo works.
Has 830cc Big Bore Kit, high compression pistons [not sure what brand].
Missing headlamp and battery.
No tool kit.
No owners manual.
No exhaust system.
RH rear axle spacer missing.
Has a few bent cylinder fins and one broken [see photos]. Fuel tank rubber hold down is bad.
Original paint. Chrome has some rust see photos.
Fuel tank has dents on left side, inside tank looks good has minor rust, includes Kreem tank lining kit, tank not leak tested. Front rim has small ding [bend].
Everything in photos included, also Includes stock air box [not shown in photos] No exhaust
Side covers are broken, forks are rusted [spare set included from 72' lowers are different but uppers should work]
Steering stop is broken, hence the LH front fuel tank dent, spare lower triple clamp included with good steering stops. There is no brake fluid in reservoir, may have a leak. Front tire [19"] holds air but is NG.
Spare handlebars and rear fender included [fender on bike has crack].
One key included, ignition and fuel cap locks work.
New rear tire, Metzeler ME77 4:00-18 never used.
I really doubt that it was stored indoors since 2009. Cough.bull..cough...#$%*...
In any event I bought it along with an extra basket case engine knowing full well that this would be a complete tear down and rebuild.
Fast forward...This is the bike in the still assembled state for planning:
I bought an alum tank and seat pan. Decided since this  not to use the tank at first... need to do some rev work to it.
I like to newer style side covers so I need to fab some (laser cut) tabs and attach:
Another fast forward:
Here she is almost completely naked:
Doin' the side flip method:
I actually did this by myself! (And took pics) Yea.
And then the bad part.......
That is a mix of oil, water, PB blaster and marvel mystery oil...
I designed an engine stand bracket and had 2 sets laser cut...worked OK.
$50 Harbor Freight engine stand.
That's all for today...Happy easter..Find some eggs with treats in them...Nuts...bolts..etc..
Re: Another CB750 build here in central PA - 1974 CB750
« Reply #1 on: April 18, 2014, 07:16:45 AM »
Welcome and subscribed. You now know to never believe the PO!
Like that tank and seat, and great job on the engine stand. Need to make one as well.
So, do you think it has an 836 kit?
« Reply #2 on: April 18, 2014, 07:28:03 AM »
Welcome!
Offline BLEAMA
« Reply #3 on: April 18, 2014, 08:06:46 AM »
Did is the operator.
It's a shame that people do not care for these machines better.
I destroyed the jugs  getting this apart. I soaked, heated, iced, to no avail. Pistons scrap too.  I was a little bit optimistic at the start but it went down hill quickly.
I ended up persuading it apart in a forceful way.
Head looked ok.
I have the cases, 2nd set of jugs (std), 2 heads, con rods, and crank at a local machine shop. They are cleaning, blasting and inspecting the components.  I could have blasted the outer surfaces, but was fearful of the residual grit. I would rather have a professional do it.  Should get these pieces back next week.
I will buy a new set of pistons based on measurements.
Bearings..TBD
Clutch, trans, and other internals looked OK.
« Reply #4 on: April 18, 2014, 08:10:00 AM »
You have a busy April left. ;)
Build time estimates are just that - estimates. Take your time and get things done right versus right now.
If you are not going with the Manx Lyta style tank, what is your new choice?
Offline BLEAMA
« Reply #5 on: April 18, 2014, 09:13:17 AM »
I have stripped the original and will be adding a "Triumph esque" stainless rack on the top.
Color of the tank will be SAAB Edwardian Grey in memory of my 1988 900 SPG.
I will be using the Lyta at some point, but not this year. I love the way it looks.
« Reply #6 on: April 18, 2014, 01:58:35 PM »
Agreed.  The shape is bad-ass and classic.
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #7 on: April 20, 2014, 08:18:30 AM »
[/quote]
HOLY SCHNIKES
 I see a lot of this on old Honda 90's cause of the head angle.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline BLEAMA
« Reply #8 on: April 21, 2014, 05:42:50 AM »
There were a couple of fasteners missing on the top side of the case too, but as I mentioned, all other internals looked "visually" pretty good.  I still need to do some measuring.
Offline BLEAMA
« Reply #9 on: April 21, 2014, 06:05:34 AM »
This is the tank that I swapped when I picked up the bike...  I had a great laugh!!
If you cant read the adhesive residue, it reads: "DON'T ASK TO RIDE MY BIKE AND I WONT ASK TO RIDE YOUR OLD LADY"
Some very minor interior rust..outside ok..  It has since been stripped.
Master Cylinder
I endured this, as many of you have....
I looked at as many posts as I could...
What a PITA.  I was ready to throw this entire master away.  Works great now.
The rear rim was ok on this bike but once the rim and tire were separated, I opted for a couple on new DID from Z1.
Rebuilt hubs.  Polished the outside, painted the centers. Zinc spokes.
Front laced:
Rear laced:
I did not want to do the truing myself. Picked them up this weekend. K70's - 3.5 front and 4.0 rear.
If you are into Harleys or any brit bike and are near Hanover, Pa...This is the place to stop and chat. Café has a ton of parts and knowledge...he also holds some salt flat records. $84 to true my rims and install the tubes and tires.
Offline nccb
  • 1974 CB750 Four
« Reply #10 on: April 21, 2014, 06:55:55 AM »
84 for both rims is pretty damn good.  I went to my local honda store and they were trying to tell me it would be in the 200s :o
Offline BLEAMA
« Reply #11 on: April 21, 2014, 07:09:00 AM »
That is what I found here.  The local Honda shop seemed confused when I asked if the could "true" a set of rims. Yamaha was willing, but a little too pricey.
I have been looking for some "go-to" shops for a variety of tasks..just in case.
There is an ebayer that sells parts.."parts bike heaven"  His shop is west of me, past Carlisle Pa.  He does work too, in addition to stripping bikes.
Offline BLEAMA
« Reply #12 on: April 21, 2014, 08:24:03 AM »
Doing a "Government Job" at work..actually a couple..for my bike.
I am not using the "ears" and decided to make my own adaptor for the top of the bellows.
I am partial to "A" or "D".  D will take less time on the milling machine, and will buff out nicely. A..will take a bit more time.
What is you favorite?
« Reply #13 on: April 21, 2014, 09:04:30 AM »
Everyone has their opinion.  Mine is for "B"!
Offline calj737
  • I refuse...
« Reply #14 on: April 21, 2014, 09:26:01 AM »
I'd like to see you mill a dust cover for the shock lower, thread the top of the lower, and relieve the internal to accept a dust seal. Then, you'd get my vote...  :)
But in the interim, B appeals to me too.
« Reply #15 on: April 21, 2014, 09:46:21 AM »
That would be a trick part!
Offline BLEAMA
« Reply #16 on: April 21, 2014, 10:38:31 AM »
That would..Hmmmm.  I like the Bellow look.
Here is what the first looks like on a fork...3D printers rule...next to CB's.
Next one:
and the back...
I don't like the little lip on the top edge of the gaiter.  To accommodate it in the design would complicate the design (for me and my machining skills).
I was thinking about just 3d printing them and being done.  I have black material.
I saw some after I was conceiving this and was thinking somebody must have made these before..
« Reply #17 on: April 21, 2014, 12:27:14 PM »
Next one:
and the back...
3d printers DO rule!  That is cool.  I would just print them and black and use them.  That is awesome.  I still like B the best, but it's your bike!
Offline calj737
  • I refuse...
« Reply #18 on: April 21, 2014, 01:00:57 PM »
I used the Joker Machine gaiter clamps on you build. They're machined aluminum and do have a recess for the gaiter lip. I've not seen any fluted though-
Offline BLEAMA
« Reply #19 on: April 21, 2014, 02:10:08 PM »
Do you have a pic of what yours look like?
Offline calj737
  • I refuse...
« Reply #20 on: April 21, 2014, 03:15:08 PM »
Here's a pic installed (gaiters pushed down) and here's the link to the product page for reference.
http://jokermachine.com/products/cafe-racer/honda-cb750-parts/cb750-fork-boot-collars.html
Offline TyMatthews
« Reply #21 on: April 21, 2014, 03:26:50 PM »
Do you think 3D-printed parts would be able to withstand the vibrational stresses and also survive UV exposure?
Offline BLEAMA
« Reply #22 on: April 21, 2014, 06:31:25 PM »
FDM (Fused deposition modeling) uses ABS or other materials.  Some of the higher end machines/systems are designed to make parts that can be used as mini run production parts. So..the answer to your question is yes and also no depending on the type of 3d printer that one might use.  Printed solid, the material may hold a thread, but again this depends on the type of material that you are printing.
The pics that I attached are just ABS (styrene). They are ok for many applications. Probably would work for a gaiter holder.
