Author Topic: 1972 CB750 Steampunk(ish) Bobber Thing  (Read 212358 times)
Re: 1972 CB750 Undefined, Vintage-inspired, Brass and Copper Bobber Thing
« Reply #500 on: June 06, 2014, 11:51:07 pm »
Ooher, that's a nice ashtray Dave, I think I've got Ashtray Envy! ;D
« Reply #501 on: June 07, 2014, 05:03:54 am »
arrgh me mateys,here be yet another treasure from the dave500 trove,it be a compass/helm/ashtray,a fitting component for the finest steampunk machine,with this rare piece of booty youll be the envy of all steam pirates arrgh!
How do you connect steampunk and pirates?
Offline edwardmorris
  • Youngish
« Reply #502 on: June 07, 2014, 02:19:08 pm »
Copper pipe  :P #trollanswer
« Reply #503 on: June 07, 2014, 02:26:49 pm »
you clap them in irons!
Online Stev-o
« Reply #504 on: June 07, 2014, 03:14:38 pm »
locks and chains
Offline vfourfreak
  • Do you think that's wise
« Reply #505 on: June 08, 2014, 03:17:48 pm »
Dave,
really ! Much as I admire your collection of brass artifacts, we really ought to leave the stage clear for the real purpose of this thread. A build of some sort if I recall correctly.
Kev
« Reply #506 on: June 08, 2014, 03:20:46 pm »
HA HA that's actually tims!
Offline vfourfreak
« Reply #507 on: June 08, 2014, 03:38:22 pm »
who be Tim then ?
Offline vfourfreak
« Reply #509 on: June 08, 2014, 04:02:20 pm »
Thanks Retro for the clarification.
I'm a bit jaded waiting on project developments here, so I'll blow ballast and sink to my slumbers.
Please carry on regardless, you who have the day to play with, I'll rejoin you scurvy crew on the morrow.
Kev
Offline vfourfreak
« Reply #510 on: June 08, 2014, 04:08:10 pm »
Kev
And I was using a submariner's term. I don't know anyone called ballast.
« Reply #511 on: June 08, 2014, 04:10:33 pm »
 ;D ;D :P
Offline Noddy78
    • Atomic Contraptions
« Reply #512 on: June 19, 2014, 10:52:59 pm »
Well if I can't do too much building, I CAN do some shopping...
So, a nice vintage Italian 19x2.15 40H from a Ducati that I picked up from a bloke in Melbourne for $30...
PLUS a 16x3.00 Harley rear:
EQUALS vintage whitewall goodness:
Add in the obligatory new bearings and brakes:
And get the lot ready to send out for powdercoating:
I've also got a spoke sitting in a bucket of vinegar out the back that's got the chrome flaking off already (gotta love cheap spokes) ready to try a rust-patina'ed effect. Will be interesting to see how that turns out...
« Last Edit: July 09, 2017, 05:41:58 pm by Noddy78 »
« Reply #513 on: June 19, 2014, 11:29:05 pm »
Good to see some movement Noddy, well done. The "chrome" on your spokes is actually zinc plating (chrome is unaffected by vinegar) and while vinegar is a nice mild acid, you could strip the zinc completely in a few minutes with phosphoric acid, which is also excellent for removing rust from inside petrol tanks etc.
If you're still thinking about copper plating the spokes, take the stripped spokes to any chrome plater, copper is the first step in proper chrome plating (copper/nickel/chrome) and they'd do them for you cheap, then you could decide whether you just want them to go dull (tarnished) while the integrity of the spoke is still protected, or polish them for that "Steampunk" look. Cheers, Terry. ;D
« Reply #514 on: June 19, 2014, 11:42:57 pm »
Vinegar will remove any rust..
Offline Sgt.Pinback
Re: 1972 CB750 Steampunk Bobber Thing
« Reply #515 on: June 19, 2014, 11:43:38 pm »
..... restoring something so it's just .. nostalgic at best. Which is fine for those who like that (which is probably a lot more folks than not), but it just isn't me.
I'm a designer by profession,
... so I'm actually doing you a favour! ;)
Andrew
Hi
..so making old things look even older is what?
.....as a designer you shoukd know: form follows function.
What kind of design is this?
....correct. Any destroyed SOHC will raise the value of ours.
Thanks and wellcome!
Doc, I love a motorcycle!
« Reply #516 on: June 19, 2014, 11:46:17 pm »
Yeah Frank, that's why all commercial grade rust removers contain Vinegar............. ;D
« Reply #517 on: June 19, 2014, 11:58:37 pm »
Not so sure if that EBC rotor will fit up but I like it.  Of course anything can be made to fit.
Online Stev-o
« Reply #518 on: June 20, 2014, 08:28:45 pm »
Those rims are beautiful....too nice for powder.
Offline goldarrow
  • one day, i'll be an
« Reply #519 on: June 20, 2014, 08:40:10 pm »
If chrome, then it won't be steampunk...???
CB550 K0
Offline Noddy78
« Reply #520 on: June 24, 2014, 09:16:53 pm »
Good to see some movement Noddy, well done. Cheers, Terry. ;D
Thanks mate, but who are you and what have you done with Terry? ;) Heh, just kidding, it's actually nice to have some positivity here. Yep, I'm all over the copper-plating process from the last build, but I've done a test spoke with a light surface rust and I think it will work fine without affecting the integrity of the spoke once it's sealed. The vinegar works fine, and it's cheap and easy, so I'll just plod away with it, I'm in no hurry.
You've actually got me there...
Sure, and I've defined it's function, which this design follows.
Actually the chrome on the front rim is already shot. Sure I could re-chrome it, but then, beauty is in the eye of the beholder isn't it (I'm pretty sure we've covered that extensively already)? The rear is just a steel Harley rim, nothing special there.
Offline Noddy78
« Reply #521 on: June 24, 2014, 09:24:28 pm »
Everything seems to line up ok, and a few blokes here have done it apparently:
http://forums.sohc4.net/index.php?topic=51179.0
« Reply #522 on: June 24, 2014, 10:02:50 pm »
According to Buzz, the EBC rotor does not fit the K models 69-76.
Offline Noddy78
« Reply #523 on: June 25, 2014, 06:16:35 pm »
Ah well, I'm sure I'll figure something out when it comes to it.
« Reply #524 on: June 25, 2014, 07:01:47 pm »
No doubt. Anything can be made to fit.
