Author Topic: My petcock is trying to kill me.  (Read 751 times)
Offline Puntas13
  • '73 cb500 '74 cb750 '09 Triumph Speed Triple
« on: April 20, 2014, 04:14:32 PM »
My 750 had a leaky petcock from the git go. It would still dispense fuel even when turned off. I put it off.
One night i was awaken at 3:30am to the strong smell of gasoline(garage/apartment). It had puked 1.5-2 gallons of fuel onto my floor. If i would have had a gas hot water heater, my house without a doubt would have exploded.
So i picked up a set of nylon washers to replace the felt ones that were messed up. It fixed it.
Flash forward to yesterday. I put in a new clutch pack. All went smoothish and i took the bike out for a spin. Clutch was slipping at certain times. It shouldn't have. Everything was good to go.
Today when looking at the bike i noticed a puddle of raw gas.  There was a drip of fuel on one of my carb overflow tubes. I touched it and fuel came pouring out. The orings failed i guess. The overflow tube was plugged and it poured about .5 gallon of fuel into my cylinder and the oil level in my tank was all the more proof i needed.
This #$%*ing thing is coming off my bike.
Long story short, is there a good bolt on replacement outside of the OEM type?
Re: My petcock is trying to kill me.
« Reply #1 on: April 20, 2014, 04:16:07 PM »
Put a clamp on your fuel line, then look for a petcock.
Offline Johnie
« Reply #2 on: April 20, 2014, 04:19:09 PM »
For the hazards you just mentioned, I install a new OEM petcock on each build. Just piece of mind I guess.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Lostboy Steve
« Reply #3 on: April 21, 2014, 02:38:04 PM »
Indeed, I do the same. It just isnt worth it finding out the hard way when it comes to fuel.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline nccb
  • 1974 CB750 Four
« Reply #4 on: April 21, 2014, 06:41:53 PM »
hell, didn't a guys bike go up in flames while he was riding it a year or so ago?
« Reply #5 on: April 22, 2014, 03:14:41 AM »
The engine should not be overfilled with fuel even with petcock ON.
Floats must be wrongly adjusted/stucked or float valves not closing as they should to stop fuel to flow into the carbs and fill engine.
