Author Topic: 1978 550k Master Cylinder Rebuild  (Read 1123 times)
Offline Farley121
  • 78 CB550K
« on: April 20, 2014, 07:35:15 PM »
  Hi All,
  Im needing to rebuild my master cylinder and I'm  a little confused about part compatibility.  I see a lot of kits for the 74-76 but not a lot of for the 77-78's.  Some listings show 74-76k and 77F together, but when I look up part numbers, the 77F is the same parts as the 77-78K.
  Is this a mistake by the seller?  would the 74-76K kits work with the 78K?  It seems as though any listings for the 77-78k is much more expensive than earlier models.
  Any help is appreciated.
Thanks
Offline eastyork1977
  • Tuning and building in the Great White North
Re: 1978 550k Master Cylinder Rebuild
« Reply #1 on: April 21, 2014, 04:05:15 AM »
most of the CB master cylinders were pretty much the same up until '76. Up until then 750 and 550 m/c had the same internals.
The 750F models in '77 up have a larger master cylinder for the dual brake system. Therefore that piston inside the cylinder shaft is larger as well so you've got two different kits available.
If its a dual disc, you'll need the larger piston kit for that over sized cylinder.
If its a single disc, the smaller kit will work. (45530-404-315 for 550).
'73 CB350G
'75 CB400F
'77 CB550K3 "Swayze"
'78 CB550K Stock
'78 CB750F2 Stock-ish
"take a peak." - Don Cherry
"If I can bounce a wrench off a tyre and it hits you, you're standing too close."
Offline Farley121
  • 78 CB550K
« Reply #2 on: April 23, 2014, 07:54:17 PM »
Thanks Eastyork
« Reply #3 on: April 24, 2014, 05:37:58 AM »
If you need the larger master kit, I've got a K&L set at the shop.
Cheers
'73 CB350G
'75 CB400F
'78 CB550K Stock
