Author Topic: 1977 CB750 K7 Resto-mod, Knoxville  (Read 97315 times)
Offline AintNoEasyWay
Re: 1977 CB750 K7 Restore (w/ a few alterations)
« Reply #150 on: October 31, 2014, 05:24:57 AM »
So I thought the original cylinder head gaskets were obsolete, but David Silver Spares is selling this: https://www.davidsilverspares.com/CB750K-FOUR-1977-USA/part_172983/
The part number appears to match up with the number on diagrams of the head. Is this the real deal? Have the gaskets come back in stock or did I misread something somewhere?
Should I buy this gasket or something else?
« Reply #151 on: November 11, 2014, 07:06:08 AM »
Alright, ordered the rest of the gaskets I'll be needing from David Silver. Head gasket, base gasket, oil pan gasket & clutch gasket. All genuine parts according to DS.
Now all I've got left to buy are the rings. Vintage CB750 has K7 rings at a slight sale (http://www.vintagecb750.com/products/82/monthly-sales), but I'm really at a loss as to what good rings I should be looking for. Partzilla lists numerous ring options for the same standard size. What do you guys recommend? Thanks for the input!
I'm expecting to get my jugs & head back from the shop this week, so I'll finally be able to start putting things back together. Looking forward to making a lot of progress now that I'll have everything fixed up & all the parts purchased.
« Reply #152 on: November 13, 2014, 06:14:20 AM »
Just found K7 standard rings, part no. 13011-392-004, on CB750supply.com for $80 for a set of 4. The description says they are genuine OEM replacement, so I'm hoping the quality is the real deal. $80 is significantly cheaper than any other set of 4 I could find; most coming in at around $130.
« Reply #153 on: November 17, 2014, 09:55:46 AM »
Picked up my engine from the cycle shop on Saturday. The head had measurements taken, new seats cut, new stem seals installed, new intake valves installed. Had all mating surfaces checked & cylinder honed.
Now it's time to sit down next to the heater in my garage & get everything put back together.
There are still a couple things I need to grab. I want to go ahead & change out front & rear wheel bearings, & so I'll be buying some All Balls. I'm also replacing drive chain & sprockets. Bought the sprockets already but still need to get the drive chain. Also need to grab some lube for O-rings & some non-hardening gasket dressing.
Then I'm off to the races. Planning to follow the classic thread (http://forums.sohc4.net/index.php?topic=107040.0) along with lots of reading from Hondaman's book. Hopefully I can get it right the first time around.
« Last Edit: November 17, 2014, 09:59:27 AM by AintNoEasyWay »
« Reply #154 on: November 18, 2014, 05:47:48 AM »
So somewhere in the process of me taking my head to the cycle shop/them subletting it to a machine shop/bringing it back to my garage, I managed to lose one of the two engine oil jets that sit on each side of the top center of the head.
The part of obsolete & a couple forum members/threads have mentioned my best luck of finding one of these parts is to just buy a used head off eBay. Sucks that something so small will stall my progress, but MRieck is going to check for me to see if he has an extra laying around. We'll see what happens.
Offline enwri
  • So that noise is normal?
« Reply #155 on: November 19, 2014, 07:24:00 PM »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #156 on: November 19, 2014, 07:39:03 PM »
Fellow MRieck had a spare oil jet for me & is sending one my way. I'm in the clear & set for progress.
« Reply #157 on: November 20, 2014, 10:47:03 AM »
Anyone have advice on cleaning/restoring front forks? What should I use to clean mine up & what should I expect to replace/upgrade. With the engine out of the bike, I'd like to go ahead & tend to these to make sure I'm getting optimal performance out of them.
« Reply #158 on: November 24, 2014, 05:19:09 AM »
Polishing the lowers front forks is popular and looks great.  I'd also plan to replace the springs, seals and oil, pretty basic.
I put Progressive springs in my K4 earlier this year.
http://www.ebay.com/itm/Progressive-Suspension-Fork-Springs-111104-Pair-/191056101424?pt=Motorcycles_Parts_Accessories&fits=Year%3A1977%7CModel%3ACB750K&hash=item2c7bd4c030&vxp=mtr
« Reply #159 on: November 24, 2014, 07:55:24 AM »
If you end up needing new upper tubes (if the tubes are pitted where they travel into the lowers), you can get new ones from Forking by Frank. Cycle X may have them too.
« Reply #160 on: November 24, 2014, 11:05:19 AM »
Awesome. Thank you, guys.
« Reply #161 on: November 24, 2014, 03:58:32 PM »
If you forks are pitted above the area where they travel into the lower forks, some people have sanded and polished the pitting (even painting the surface).  If the travel area is pitted, however, it will destroy your fork seals (like sandpaper).
« Reply #162 on: November 25, 2014, 07:47:16 AM »
I do have some rust on my right fork that I will try to clean up. I'll post a picture for you guys to see when I get home later.
« Reply #163 on: November 27, 2014, 05:10:22 AM »
Alright, guys, here's a photo of the rust on the front right fork below. It doesn't look bad to me, but I don't know if it's still progressed enough to do damage in the fork. What do you guys think? I used some aluminum foil & water to clean the surface rust & now the photo shows what's left.
Also, I am trying to clean up my head & cylinder. I bought some regular O'reilly's degreaser, some ZEP purple, and S100. Thus far I have actually been able to get a good amount of grime off the two parts with just a tooth brush, scotch brite pad, & WD40. The exhaust ports on the head will be very difficult to clean though. Are all of the above products still safe for me to use if I leave the springs, valves, stem seals in the head while I clean? I don't have a way to take out the springs, but want to be sure that the valve stem seals aren't damage from the cleaners/ degreasers.
I'll be rinsing everything off & then blow dry with an air compressor. Let me know if this is okay. Thanks!
& happy Thanksgiving.
« Last Edit: November 27, 2014, 05:13:26 AM by AintNoEasyWay »
Offline enwri
« Reply #164 on: November 27, 2014, 05:50:50 AM »
When you mentioned that you have some pitting on the fork I thought maybe you could get away with cleaning them up a bit. Now even I would have to draw a line at that, sorry.  That's a bit beyond polishing. Or throw a set of boots over them and try to avoid any motocrossing. They will jump ok, the landings can be a little heavy though.
8? XJ 550 meh...
« Reply #165 on: December 06, 2014, 04:23:15 PM »
Time for a new set of tubes. May as well change the springs too, if you havent done it.
« Reply #166 on: December 07, 2014, 07:52:57 AM »
Alright I'm on it. Will be a while until I can get those forks rebuilt as that's just another expense to add to the rebuild.
I have a new Tsubaki cam chain I'd like to install for my engine rebuild. Do I need to break open the crank case in order to install it? Maybe a newb question, but I'm not seeing how to install it otherwise.
Offline Trad
« Reply #167 on: January 29, 2015, 12:19:23 PM »
You can get a soft link for those chains and order a good rivet tool like the Motion Pro Version. I just did this on my cb550K rebuild. Easy as pie.
Nice looking bike man!
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
« Reply #168 on: January 30, 2015, 08:42:36 AM »
Thanks a lot, Trad. I don't own a rivet tool/chain breaker yet & definitely need one for putting my new drive chain on anyway. Is this the one you're thinking of?: http://www.motionpro.com/motorcycle/partno/08-0058/
Offline Restoration Fan
  • My wife will never call me
« Reply #169 on: January 30, 2015, 08:47:48 AM »
Oh, come on, Nate.  Go ahead and break open the cases.  What could go wrong? ::)  *says the guy about to help his son put the cases back together for the 4th time*
« Reply #170 on: January 30, 2015, 08:48:56 AM »
Haha! Exactly what I was thinking after I read that first sentence.
« Reply #171 on: January 30, 2015, 08:54:27 AM »
I've got all my parts ready for the clean up. Man, it's been a long time coming, I know. It looks like I may be ordering a different head gasket though. The "genuine" head gasket that I bought from David Silver Spares doesn't line up correctly. Maybe the product is mislabeled. Just a heads up to anyone else that may consider the same item, here it is: https://www.davidsilverspares.com/CB750K7-FOUR-1977/part_8011/
I think I'll just purchase a Vesrah gasket & get on with the work. I need to make a run to Lowe's/Home Depot tonight for some cleaners, acetone, denatured alcohol, grease, & metal rescue. There's a lot of stuff I'm getting to sort of build up my garage. I'm new to every bit of this, so along the way I've had to buy a bunch of tools & the like. This has become much more than just a rebuild. But that's great in a lot of ways!
« Reply #172 on: January 30, 2015, 09:06:16 AM »
I know the feeling 100%.  In the end though, it means you have more tools...and that's never a bad thing!  ::)
The bad thing is that Logan & I have had to take this engine apart several times now.  The good thing is that I am now INTIMATELY familiar with the interior of the K8 internals and I think they're pretty much identical to the K7.  So, don't hesitate to call or text if you think there's anything I can help with.
« Reply #173 on: January 30, 2015, 10:51:06 AM »
Thanks again, Ron. You guys are having way too much fun down there. I'm hoping to make some progress this weekend &, also importantly, actual updating my rebuild thread!
« Reply #174 on: February 01, 2015, 07:47:58 AM »
Ahh, the more of Dino's Hack a Week vids I watch, the more I really am tempted to take apart the cases & inspect everything. Plus, last night I came back across an old video I'd saved of a bike I liked: https://www.youtube.com/watch?x-yt-cl=85114404&x-yt-ts=1422579428&v=67xmWf7U9IM I really dig the engine paint on this, & think it'd be great to have my cases black like this, helping the polished chrome to stand out.
