Author Topic: 1977 CB750 K7 Resto-mod, Knoxville  (Read 114855 times)
Offline AintNoEasyWay
Re: 1977 CB750 K7 Resto-mod, Knoxville
« Reply #475 on: July 30, 2015, 05:46:02 PM »
No bubble when I put it on reserve. Flows much better so guess I just didn't put enough gas in. Still won't start though. ???
Offline enwri
  • So that noise is normal?
« Reply #476 on: July 30, 2015, 05:49:03 PM »
Ahh, the old reserve trick.
 Tried the choke?
Spark at the right plugs at the right time next
Kill switch?
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
« Reply #477 on: July 30, 2015, 05:55:09 PM »
 Tried the choke?
Kill switch?
Hahaha! Will have to check spark. Definitely getting gas flow. Have a leak from carb #3 now!! Will pull them now. Agh!
Offline enwri
« Reply #478 on: July 30, 2015, 05:58:02 PM »
you know you can leave the top half of the airbox on to get them out, easier to get the aibox tubes off and on easier
8? XJ 550 meh...
Offline Restoration Fan
  • My wife will never call me
« Reply #479 on: July 30, 2015, 05:59:11 PM »
First things first.  Eliminate one thing @ a time.
Take a spare spark plug.  Pull the cap off #1 and put the spare plug into the cap.  Touch the plug to the engine (make sure fuel isn't on) and see if you get a spark arc'ing over to the engine as you hold in the electric start button.  Repeat that process for each spark plug.
If, at the end of this process, you have spark @ all 4 plugs, then spark is most likely not your problem (theoretically, you could have a bad plug and would have to unscrew each plug and test to confirm but the likelihood of that is so small that I would only try that after everything else).
Once you have eliminated spark, then it's most likely a fuel problem.  Personally, I'd remove the air box and start the bike without an air filter on it.  This lets you visually confirm the slides are completely closed when you have it on full choke.
Also, go get some more fuel.  Put enough in there that the the tank is 2/3 full and just eliminate that as a potential source of problems.
« Last Edit: July 30, 2015, 06:01:44 PM by Restoration Fan »
« Reply #480 on: July 30, 2015, 06:01:12 PM »
That's more of a pain in the butt with the K7's and K8's than with the earlier K model air boxes.
On the air boxes up until 76, the rod that goes down through the bottom connects via a wing nut.  On the K7's and K8's, the rod connects into a molded plastic piece in the bottom of the airbox (that often strips).  Not that you can't do it...it's just a bit more trouble with Nate's bike than it would be with earlier models because you screw it in from the top and that would be hard to do with the top still connected in the bike.
« Last Edit: July 30, 2015, 06:07:53 PM by Restoration Fan »
Offline enwri
« Reply #481 on: July 30, 2015, 06:11:46 PM »
Same as mine. k7. Someone ground slots on the heads of those long nuts on the bottom half.
« Last Edit: July 30, 2015, 06:16:16 PM by enwri »
8? XJ 550 meh...
« Reply #482 on: July 30, 2015, 06:13:52 PM »
Solid advice. Thanks as always, Ron. Just confirmed spark at all four plugs. Move on to carbs?
« Reply #483 on: July 30, 2015, 06:29:40 PM »
Calling it a night. Air box is off & I see that accelerator pump is shooting gas into each carb in the proper way. No issue there.
« Reply #484 on: July 30, 2015, 06:39:51 PM »
Also just confirmed that slides close completely at full choke.
Offline enwri
« Reply #485 on: July 30, 2015, 06:45:47 PM »
As long as it's sparking at about the right time as well (static timed?) it should at least fire, are you trying the throttle as it cranks? If it's 180 out it will pop and bang but not run,
Did you give no3 a tap to try to stop it flooding?
 can you smell fuel on the plugs?
If every thing is clean and set it should just run, if not all you can do is clean and check again until you find something.
Remember those tiny little holes and passages in the carbs?
The rest is mechanical, if it all does what is meant to, (and it should when assembled correctly) the carbs rely on air pressure, pressure differences and fuel being drawn up through those tiny little apertures, little differences in hole size make a huge difference, just being unblocked isn't the same as clean. thousandth's of an inch difference makes a difference. (Jet sizes)
If you have it started already before i've finished writing this then it must be close enough
8? XJ 550 meh...
« Reply #486 on: July 30, 2015, 06:53:36 PM »
Hey enwri, I backed the idle adjuster all the way off because I didn't want to rev it. I was following Hondaman's instructions here: http://forums.sohc4.net/index.php/topic,12686.msg122510.html#msg122510
Kicked it about 40 times & tried to start but never twisted the throttle.
Carb #3 wasn't overflowing from the float bowl drain. I think maybe the gasket isn't seated right or there's a gap somewhere else because it seemed to be flowing down the side of the float bowl.
I did wonder if we maybe have the cam 180 since that was a concern before. But I'm pretty sure we had it 180 at first, then switched it to the correct position.
Offline enwri
« Reply #487 on: July 30, 2015, 07:11:04 PM »
You'll know if the ignition timing is 180 out. Big bangs pops and maybe even flame shooting out the carbs and pipe. Don't worry about the cam bit, that's valve timing, it's right, you had it on the right cam timing marks, it won't care if the cam is 180 out, as soon as you turned the crank another 360 to the 1-4 marks that perceived problem disappeared, anything other than exactly 180 and it's trouble though. If you managed to get the tappet gaps set and didn't end up with loose tappets and giant gaps it will be ok.
It may need a bit of throttle to start initially. Backing out the idle screw is just a precaution to stop it from accidentally overrevving on startup.
« Last Edit: July 30, 2015, 07:16:25 PM by enwri »
8? XJ 550 meh...
« Reply #488 on: July 30, 2015, 07:17:17 PM »
Why not take a video of it trying to start and put it on YouTube, then link it here?  Maybe someone will be able to help you solve the issue.
Offline enwri
« Reply #489 on: July 30, 2015, 07:25:42 PM »
If you make a video, take off the tappet adjuster covers and make sure the valves are actually moving down, if you set them the way you had it first, like you were trying to, the valves wont open and will have giant gaps when the valve should be closed, and have the little gap instead of opening when they should be open.
I thought that got worked out back then though, not sure.
8? XJ 550 meh...
« Reply #490 on: July 31, 2015, 06:40:54 AM »
Yep, worked that out back then & everything was closing/opening properly once we switched the cam over & set the gaps correctly. I'll take a video during my lunch break & throw it up for you guys to see. If I have enough time during lunch i'll get the carbs off & start checking them as well.
It doesn't matter which spark hose/plug cap goes to 1-4 or 2-3 from the coil right? E.g., as long as the hose/cap from 1-4 coil goes to 1 or 4 then it's fine? etc.
« Last Edit: July 31, 2015, 06:43:51 AM by AintNoEasyWay »
Offline enwri
« Reply #491 on: July 31, 2015, 07:28:35 AM »
yes,  Either lead from Coil 1-4 on cylinders 1 and 4, either lead from coil 2-3 on cylinder 2 and 3
« Last Edit: July 31, 2015, 07:39:20 AM by enwri »
8? XJ 550 meh...
« Reply #492 on: July 31, 2015, 08:39:50 AM »
First start:
All I did was tighten up the idle adjuster on top of the carbs. I had it completely backed off.
My tachometer isn't reading anything though. Maybe I reconnected it wrong.
Have some smoke coming from exhaust around #3. Seems like the tappets are a little clangy. Need to make sure oil is getting up to the top end! I will follow Hondaman again:
When I rebuild these, I begin by kicking them over about 40-50 times in as much a continuous session as possible (it helps you lose weight!). Then, short bursts of 2-3 seconds of the starter until the oil light goes out. Then, when my leg recovers, I do it a 2nd time, then start it and run, as slowly as it will run, for about a minute.
The kicking/bursting routine will fill the oil filter and the lines, but will not force oil into the bearings the first time. After the second time, it will. The top end will not be oiled until the engine has run for a minute or so, due to air in the system at other points, so don't rev it until it's running pretty smoothly.
« Last Edit: July 31, 2015, 09:27:01 AM by AintNoEasyWay »
Offline Desert-SOHC
  • It's old
« Reply #493 on: July 31, 2015, 09:36:52 AM »
Outstanding!!
Seems like your idle is low for full choke though. At full choke on mine I have it adjusted to run at 3,000 rpm. These things are REALLY cold blooded and mine doesn't run decent for about 15 minutes of riding....till its good and warm. You will be doing little adjustments on the first ride so be aware of that. I think I had to adjust my idle3 or 4 times till it warmed up all the way to operating temp, along with small adjustments of the rear brake. Other than that is sounds good...the standard SOHC "chuggle" I call it.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #494 on: July 31, 2015, 09:39:47 AM »
Outstanding!!
Thanks, Desert. I had it running for about a month last summer & did some short riding before I started having a bunch of problems with it & pulled the engine. Back then, I could get it to idle with the choke in at about 1750. Can't remember what it idled at with the choke out. I need to get that tach working so I can know for sure.
« Last Edit: July 31, 2015, 12:29:14 PM by AintNoEasyWay »
Offline Desert-SOHC
  • It's old
« Reply #495 on: July 31, 2015, 09:47:20 AM »
Get out there an ride it now!!!!!
11 Ranger S/C 2wd
« Reply #496 on: July 31, 2015, 11:58:55 AM »
OUTSTANDING!
A September ride is looking like a sure thing now, Nate!
« Reply #497 on: July 31, 2015, 02:43:02 PM »
Came back after work to try idling the bike for a minute & get oil up into the top end. #1 exhaust seems cold but the other pipes are hot. It also started smoking some out the exhaust & around the carbs. Air box is still off & I haven't tuned the carbs yet. Any advice on how to proceed would be great!
I checked the oil tank & over half of the oil that I just filled it up with is gone. I assume it worked down into the engine. So I filled the oil tank back up again.
« Last Edit: July 31, 2015, 03:06:29 PM by AintNoEasyWay »
Offline Desert-SOHC
  • It's old
« Reply #498 on: July 31, 2015, 03:17:26 PM »
With a first startup there might be a little "burn-off" so that may be where the smoke is coming from. Sounds like #1 isn't firing or is starving for fuel, either way the problem needs to be found before continuing. Pull the plug and see if its wet.
11 Ranger S/C 2wd
« Reply #499 on: July 31, 2015, 03:33:36 PM »
Ok first picture is plug #1. Does look wet on the threads but not on the actual plug. Photo two is plug #4.
